Is mouthwash taboo? (1 Viewer)
T
Tackle man
I have been advised not to use mouthwash in the motorhome, the chemicals can cause the seals in the plastic plumbing to leak. Is this true?
DanielFord
3,020
3,086
I can't see why that would be true, a lot of mouthwash does contains alcohol, I would have thought that would cleanse the pipes rather than corrode them. I could be wrong of course.
Jaws
23,832
72,343
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I spose it could cause them to dry out eventually, but I would hardly rate it as high risk to say the least !
mikebeaches
5,392
8,594
Bristol
Rapido V68 Van Conversion
Since 2009
I also read a post on a motorhome forum concerning damage to a plastic sink, supposedly caused by using mouthwash?
I guess you could dilute the used solution by running some fresh water in the sink and down the drain.
Mike
movan
21,492
120,753
Moving around
Burstner
since07
I thought it was a health question ..... so on that note ............. when going through chemo we used to all meet up regularly for lunch and discuss latest health statistics etc... We all changed to alcohol free mouthwash because statistically normal mouth wash may contribute to mouth and tongue cancer ... I don't have a link but I am sure there is one somewhere .
We also gave up on deodorant and talcumn powder ... so apologies for the body odour.. :)
Sep 5, 2012
2,109
42,124
Scotland
East Neuk Fifer
since 2012
I thought it was a health question ..... so on that note ......it doesn't stay in my mouth ...... when going through chemo we used to all meet up regularly for lunch and discuss latest health statistics etc... We all changed to alcohol free mouthwash because statistically normal mouth wash may contribute to mouth and tongue cancer ... I don't have a link but I am sure there is one somewhere .
Because of tongue cancer I only use alcohol free but I still drink the stuff (not mouthwash) but I suppose it doesn't stay in my mouth long enough unless I'm savouring a malt. Seriously I asked if ok to drink and ok in moderation. (y)
T
Tackle man
I too read it on here a couple of years ago. Here you go.
Thanks Bailey58. I have also just heard from my MH dealer who confirms several vehicles have indeed suffered from plumbing damage caused by certain mouthwash brands.
Feb 16, 2013
19,699
51,883
uttoxeter
ambulance conversion
50 years
Serious question, not having ever used it , why do you use any sort of mouthwash, isn't toothpaste enough?
43,304
49,291
Please Joy, do stop believing everything you are told.
Mouthwash contains alcohol but regular use doesn't make you an alcoholic.
The chances of mouth cancer are so small only the scaremongers would mention it.
If you believed everything is not good for you then you would have died at birth.
TheBig1
17,601
43,067
my dentist swore me off mouthwash, as it actually makes your teeth soft and burns your mouth. as for motorhomes, i have seen several nearly new vans with sinks stained by people who use it
nasty toxic stuff, like gargling with bleach or toilet cleaner
Jun 22, 2012
3,754
40,732
Sherborne Dorset
Van Conversion
Since 2012
My old dentist reckoned cleaning your teeth twice a day plus flossing was enough. He also said the main reason for the alcohol was the stinging sensation so that people thought it must be doing good. Completely different if like Movan you are having chemo, often the mouthwash helps compensate for the fact that its so hard to clean bleeding ulcerated mouths with floss and toothbrushes. I am seeing my new dentist Pedro on wednesday so will ask him, although he is young, gorgeous and Portuguese so I might forget!
movan
21,492
120,753
Moving around
Burstner
since07
Yes, if your gums bleed when you clean your teeth, the mouthwash stops the bleeding so no infection can get in the damaged gums... Salt water does more or less the same thing though.
movan
21,492
120,753
Moving around
Burstner
since07
Yes, that is what we were told... You drink alcohol and usually it doesn't stay in your mouth long enough to do any damage .. especially if you are having a meal at the same time, whereas mouthwash is used to swill your mouth and throat ... usually after eating and drinking and well in advance of your next meal.
movan
21,492
120,753
Moving around
Burstner
since07
Should have added, that was a few years ago but the surgeon who I still see now tells his patients not to use these either as it is now an accepted breast cancer risk apparently. When fighting cancer you grab at anything that doesn't entail any hardship to your lifestyle rather than go through chemo again.
movan
21,492
120,753
Moving around
Burstner
since07
I use bicarbonate of soda to freshen my mouth and a mouthwash called Biotene for dry mouth. I have to try and keep infection at bay as radiotherapy has done some damage.:(
Thank you for that. I will try it.
I use crystal 'deodorant'. It isn't as good as the real stuff but it works.. (I think!!!) but you need to apply it more often ............. or take extra t shirts to change into :)
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Just shows you, my dentist advised me to use the stuff and having seen what been said will check the MH sink tomoz
Thks
Minxy
32,624
66,460
E Yorks
Carthago Compactline
Mouthwash used sparingly should be okay a MH so long as you rinse the sink/pipes afterwards, we've never ever had a problem with leaky pipes and to be honest if mouthwash causing such an issue I'd be questioning the quality of the materials used!
I have to use mouthwash, not for my teeth, but as I have very narrow Eustachian tube (it drains from your ear to your mouth) and the tangy mouthwash makes me produce saliva which encourages the tubes to empty, if not I get horrendous problems with my ears, but I only have to use a small amount.
As for the other things mentioned which are not 'good' for you, such as deodorant which I use and talcum powder which I don't I'm sure there are many more 'dangerous' things we use/do everyday than using them.
Nov 28, 2007
428
1,517
For years it has been said that mouthwash will crack your basin etc, another excuse by the van builders to cover up for very poor quality basin mouldings that are paper thin just like shower trays. No reason other than profits for them to make them so thin.
Oct 12, 2008
6,287
22,395
Balma (next to Toulouse) France
HymerCamp 51Capucine
Since 2011/owner since 6/03/2014
I've always been told by any dentist I have visited for tooth extraction or serious care causing open wounds to never use such a thing for more than 5 days. Mouth is supposed to defend itself with its own little people, and using mouthwash destroy oral flora (hope the word is correct as I've asked google).
I never use it without a prescription. A drop of Ricard calms down any mouth pain;) ... and it's quite nice!(y) Of course ... you understand you cannot have pains every day :rolleyes:
Can't crack Max's bathroom sink then!
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
I understood that sinks made from certain plastics, styrene I think, may have a problem with some mouthwash products. PVC pipework shouldn't suffer though.
T
Tackle man
Well bless my Sister's cat's backside ..... I didn't know that!!:clap2::whistle2:
TheBig1
17,601
43,067
ooooh do tell us, do you often kiss your sister's pussy?:rofl:
dabhand
4,307
23,935
Staffs
Concorde carver E35
Since 1993
Is mouthwash taboo? More like Taboo is mouthwash!:D
May 21, 2008
4,270
7,338
Oxford
WildAx Constellation
Since 2008
Frankie, in my experience Ricard calms down absolutely any pain... and it's more than just nice!
