IS IT MY AGE?
Discussion in 'Motorhome Chat' started by cazian, Dec 2, 2014.
  1. cazian
    cazian Funster
    Jan 14, 2014
    17
    14
    wales
    I've been looking at 12v tyre inflators to inflate my motorhome tyres if it's required.
    Been to halfords, looked on the net, the specs all to be a tad vague when it comes to the pressures they will inflate to.
    Can anyone recommend one?
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
  3. Borderland
    Borderland Funster
    Nov 5, 2014
    422
    2,334
    Borders
    I've got the RING type and find it good to use and quite accurate.
  4. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,039
    8,017
    Forest of Dean
    I have an old Ring one which does a reasonable job but don't believe the inflatable pressures they quote. Mines quoted at 130 psi not a chance in hell the most it gets to is 80psi and takes forever to get there. These little 12v pumps are okay for topping up not much use inflating from flat.
  5. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,570
    7,668
    Tropical Bar,Benidorm.
    • Like Like x 2
  6. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
  7. golly
    golly Funster
    Aug 16, 2009
    1,124
    2,058
    Co Durham
    Whatever one you get, if you need to use an extension lead, make sure it's a heavy duty one or the power loss will make it struggle
  8. Brisey
    Sep 4, 2007
    6,570
    7,668
    It's used by the AA & RAC breakdown patrols as standard equipment I am told. It certainly does the job.
    Brisey.
    • Like Like x 1
  9. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,694
    13,303
    Norfolk
    As a portable compressor I have a Nu Air Boxy 1.5 HP 8 bar 116psi. Cost around £100 , noisy but powerful.
    • Like Like x 1
  10. scotjimland
    Jul 25, 2007
    28,934
    25,589
  11. trekkin
    trekkin Read Only Funster
    Sep 12, 2014
    333
    495
    Staffordshire
    I second that. Got one it's brilliant
    Be aware it's not a toy one so cannot connect to 12v power point. Needs direct connection to battery, but will inflate MoHo tyres to the high pressures required even with the increased volume, with good gauge and coiled hose gets around the van.
    Don't waste your money on anything else
  12. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    • Like Like x 1
  13. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    This is the one i have....
    http://www.maplin.co.uk/p/nikkai-he...s8W5DtzL_3EjlMvVboFQGKM9_awrhJWfjAaAsCD8P8HAQ
    I modified it to charge a 40ltr compressor tank via the tanks own automatic pressure cutout switch which cuts power at a pre-determined pressure....that pressure is 115psi.
    Both the inbuilt gauge and the comp tanks own gauge show switch off between 112 and 115psi.
    Takes around 7 minutes to charge the tank from empty.
  14. scotjimland
    Jul 25, 2007
    28,934
    25,589
