Is it long enough? (2 Viewers)
TheDeckKing
137
114
Hyde, Cheshire
Talbot Voyager 2 coachbui
Newbie
We're off on our first week away in Baz tomorrow. Its just crossed my mind that my EHU lead is only 10m long. Will this be enough? We're staying on caravan club sites all week. Are the EHU points always close to the pitches?
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
As a general rule the CC let you choose your own pitch, so you can pick one where you lead reaches the power point!
10,190
57,440
Market Harborough
C Class Laika Ecovip 7R
10 metres should be long enough, there might be time you need more so in future you could carry another, of say, 25 metres, which you could join with your other one. ;)
MikeD
3,936
3,697
London
IH PVC
Since 2012
Caravan club pitches almost always have a EHU reasonably close.
Not sure you could say that if you take your motorhome onto the continent.
I have 2x 25mtrs and have used them both in the past. (not sure how many volts I got at my end but everything worked) (y)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Caravan club stick to regs
All pitches are within reach of a 25 metre lead as BS7671
R
Robert Clark
It can never be too long !
Seriously.
Get a 20m to go with it, then The World is your oyster.
We've got a 50m reel in reserve - just in case
Plus a 15m cable for every day use
Better to be safe than sorry
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes as John said! same applies to all coiled cables. Read this one carefully
sean n maggie
672
327
leeds
autotrail
i have a 5mtr 10mtr and 25mtr nice sometimes when you get close to a hook up not to have to unwind the big reel.......(y)
MikeD
3,936
3,697
London
IH PVC
Since 2012
Whatever length lead you use always make sure it is either very loosly coiled or preferably fully unwound and laid out safely.
A tightly coiled lead, ie: on a cable drum etc, is a potential fire hazard
It basically acts like a coil on an electric fire if you don't. (y)
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Stick to the regs which is 25 meters 2.5sq mm and not artic blue which is not rated for outdoor use
The correct cable is a Rubber insulated cable to HO7RN-F or HO5RN-F
cruiser
4,219
4,951
northampton
coach built elddis 400
since 1978
I have never had to use any longer than 25 mtrs. I think I might ad a longer one.
makems
3,440
27,699
Ingleby Barwick,,Teesside
Sadly had to give up
I have 2 x 25m plus a 10m and have had to use all three joined together on a couple of occasions on Spain and Morocco.i always use the shortest cable if I can to avoid having cable coiled up. I've never stayed on a Cc site so no experience.
Brian and Jo
3,002
6,447
oswestry,shropshire
A-Class N+B Arto 88F
Been motorhoming for 15yrs.had an American RV for 7yrs,Now got a Niesmann Bischoff Arto 88F
your safe on CC sites,the hook up point is always pretty close to the pitch(y)
brian and jo
Candapack
711
2,639
Fife, Scotland
Since 2013
On recent France trip, mixture of sites and Aires. In 6 weeks, I only got away with using a 10m cable twice, once had to join it to the 25m one, for all the rest the 25m one was fine.
Keef
33
13
Hereford
Low profile
15 Years
I'm assured that Arctic blue is the best cable for outdoor use as the name suggests it isn't affected by cold weather
Gorse Hill
2,364
1,944
Stretford
Not true artic blue does not have
BASEC approval as it deviates from British standard and not rated for outdoor use at 240v
Arctic cable is rated at 300/500V it is not suitable for use at those voltages in some circumstances. Reg 704.522.8.11 which says that on construction and demolition sites 300/500V cable shall be used for reduced low voltage (110v) applications, but at voltages exceeding that then 450/750V (H07RN)cable shall be used.
At volages exceeding reduced low voltage, therefore 300/500V cable is unsuitable for ALL temporary external installations at standard low voltage
BS 7671 clearly states that the caravan should be connected by H07RN-F cable. Looking at the specs for H07RN-F and Artic cable it can be seen that H07RN-F cable is a much tougher cable.
The only anomoly is that the regulations refer to H07 and H05 cable for the same purpose. As this only relates to the voltage capability it should not matter as there will not be caravans with supplies higher than 500V
Roryboys Dad
631
805
Glapwell Derbyshire
Pilote Reference P716 LPR
mitzimad – the Aire might be a bit too far for your next holiday – it's on the way to Cape Reinga at the northern tip of North Island, New Zealand.
:france::france::france:
calion
406
527
C class
since 2008
As long as he's got a full tank of diesel................
