Is it feasable...
Discussion in 'Motorhome Chat' started by old-mo, Oct 1, 2014.
  1. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,992
    40,249
    The guy that owned our van before us,,,, had a "Dometic" all singing Air-Con/heater unit fitted ....
    Next to bloody useless unless you are on a good 16 amp EHU... :(
    And inverter is on max when using that....
    Is it possible to do away with,,,, and put a standard Fan Assisted Skylight in the hole.. ?
    Could not sleep with it on anyway... :sleep::(
  2. buttons
    buttons Funster
    Aug 27, 2009
    14,316
    11,618
    Hertfordshire
    Other option is an on board generator. My brother had this set up and worked well.
    • Like it Like it x 1
  3. old-mo
    Oct 16, 2008
    12,992
    40,249
    I have a 1 & 2l , Honda... but I think the 1l. would be screaming it`s guts out..:(
    And you know the thoughts of a lot about on site genny`s,,,, especially when we would use it... at night.. ;):D
  4. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,921
    23,685
    Narrfoook
    Ok,, thinking a bit out of the box here...
    You could remove the guts of the AC unit and fit a power fan in it instead.. No disturbance to any seals and no possible new leak points...
    • Like it Like it x 3
  5. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,462
    7,374
    Derby
    Spoke to the buyer of my Burstner (sold it in July) , first thing he did was remove the roof aircon unit (too noisy anyway) and fit a roof vent. Said it was straightforward and let loads of light in over that area - wished I'd thought of it myself:doh:
    (y)
    • Like it Like it x 2
  6. old-mo
    Oct 16, 2008
    12,992
    40,249
    That was my thinking, if it can be done,,, it`s right by the eye level oven & grill so would be good for getting rid of the heat and cooking odours..
    I can only presume the middle roof light was removed to facilitate the A/C... as I have not seen another model the same as ours with A/C in that position..
  7. SteveandDenise
    SteveandDenise Funster
    Sep 26, 2011
    610
    754
    Spalding LINCS
    As you know our van is the same model as yours and has a roof light where your air con is fitted the mesurements are 40cm x40cm. You may have to remove the inside trim to get the true size of your hole in the roof. Alternatively have a look at the fitting instructions of your air con unit this will give you the cut out size.
  8. Tootles
    Tootles Funster
    Sep 14, 2013
    9,322
    33,524
    Lancaster
    We have a 'Trav-L-Cool' system fitted in the roof. Works on 12volts, can be used with either a two speed fan, two speed extract, on the move, or as a water cooling fresh air input. I have to admit it works very well since I repaired it, and soon cools the inside down in a hot day. However, if the humidity is very high, it's not as effective.
  9. teddybard
    teddybard Read Only Funster
    Aug 21, 2012
    7,610
    8,996
    warwickshire
    Heike roof vents seem to do the same thing without all the fuss Mo
    will let you know how well after they are fitted Friday.
    Roger & Sheila
  10. chrisboyo
    chrisboyo
    Aug 5, 2009
    1,338
    825
    Newport South Wales
    Very interesting !!
    We also have all singing n dancing air con and the same thought has occured to me, for the same reasons.
    Let me know how you get on with it
    Happy Daze
    Chrisboyo
  11. chrisboyo
    chrisboyo
    Aug 5, 2009
    1,338
    825
    Newport South Wales
    Just as an addition
    We found that a 9 inch desk fan, plugged into the inverter did the job just as well and quiter than aircon and we could leave it on while sleeping
    Got me excited now !!
  12. Terry
    Terry Funster
    Dec 27, 2007
    10,789
    6,295
    South yorks
    It's not a problem Mo and if you put a roof light in it will probably be a better seal because they don't have moving parts/may be a fan to break the seals
    terry
  13. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,922
    12,113
    Taunton Somerset
    The best fans in the world are "Fantastic Fans" American, will fit a 40cm x 40cm hole left by your Air Con unit
    The European versions just don't have the same power v noise ratio in my opinion
    Eddie
  14. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,224
    15,205
    Leeds the one up North
