Invertor load draw question
Discussion in 'Tech/Mech General' started by Peter & Elaine, Aug 2, 2016.
  1. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    4,035
    6,559
    Roobarb land
    is I correct in assuming that a
    12 volt to 240 volt invertor with a 800 watt constant load a a surge load of 1400 watt
    Has the potential to pull a currant from batterys of 115 amp at full load and around 60 amp at 800 watt
    The resson I ask is the supply cables provided look much too small 50 amp maybe
    They are about a quarter inch diameter
    My old 2200 watt one where about half inch diameter that I am using now but would like to get rid of so I can tidy up a bit and lighter cables would make it easer to do so
    The cable run lenth battery to invertor would be about 3 foot
    All help greatfully received
    Peter
  2. Steve
    Steve Funster Life Member
    May 8, 2013
    1,601
    1,903
    Compton Berkshire
    in my opinion a 115amp load at 3ft you should be using 25mm cable. 16mm will work but likely to get warm so using power. dont forget fuse.
    • Like it Like it x 1
  3. xsparks
    xsparks Funster
    Mar 11, 2013
    225
    119
    Gillingham
    That's the cross sectional area not the diameter.
  4. scotjimland
    Jul 25, 2007
    28,993
    25,691
    Suffolk
  5. Mr Mousy
    Mr Mousy Funster Life Member
    Sep 9, 2013
    308
    1,702
    SA14 9NH
    Peter, I have some cable that may do the job - which you are welcome to. Are you going to Malvern? If not I will post.
    Regards Martin
    @Peter & Elaine
  6. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,068
    12,423
    Plympton, Devon
  7. Peter & Elaine
    Aug 30, 2012
    4,035
    6,559
    Roobarb land
    Thanks for your kind offer but I can get my hands any size cable at the place I work part time
  8. Peter & Elaine
    Aug 30, 2012
    4,035
    6,559
    Roobarb land
    After looking though advice here and in links provided I think I have Sused out my problem
    I have been confusing cross section and diameter
    I have some good quality heat resistant 8 mil diameter cable that very flexible that I think will do what I want
    And when considering that the max load we would would ever put on the inverter is 700 watt about 60 amp battery load I am fairly sure it will be more than good enough with a 80 amp fuse on battery end
    Unless someone tells me my calcs are wrong
  9. Steve
    May 8, 2013
    1,601
    1,903
    Compton Berkshire
    well if the op does not know what i meen i'm thinking that maybe someone else is doing it for them.(y)
