inverters (1 Viewer)
Lord Mac
190
232
Devon
Autotrail
I'm a newbie
Can someone explain, in non technical language, what inverters are? Why use them and how do you use them? Any draw backs?
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
They convert 12v power to 220/240v Hammer batteries better to use 12v things where possible ::bigsmile: ie 12v telly lights etc No hairdriers or other things that use 240v especially heavy power hungry items :winky:
terry
edit forgot to say 1000 watt inverters are reasonably priced but are not usually big enough to power most 240v items and once you start looking at bigger the costs rise a lot and you need bigger battery banks to use them
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
How do they harm the battery ?
Had been looking at one for phone chargers etc .
Small ones are fine but also use about 10 % more power than straight 12v -- did not say harm batts just hammer them :winky: ---see my edit
terry
Oct 1, 2013
7,511
19,934
Lanzarote
Nil by mouth
Lots
terry
Cheers :Smile:
So what rating would we need if we decided to power a laptop ?
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
A small 300w (£20)one will run/charge item fine -will also run a tv etc but better to try and use 12v every time
terry
Jan 3, 2008
3,337
5,356
Pakefield, Lowestoft, Suffolk, UK
Looking
A box of tricks which is connected to your leisure batteries and when switched on converts the 12 volt output from them to 230/240 as if you were on domestic mains power. There are many sizes small and large, some of the smaller ones are portable and plug in to your vehicle cig lighter of 12 volt plug.
I prefer a permanent fixture connected via an isolator switch to my leisure batteries and I have a 1000 watt inverter which produces 83 amps, therefore I can run any 240 volt appliance provided it does not exceed 83 amps (although the inverter can go unto 2000 watts for a short surge) This is just about OK for our low power toaster but you could not use a hairdryer. items that produce heat are not usually compatible with inverters but my toaster works ok for a short period.The 1000 watt inverter is large enough to power our laptop and charge mobile phones. The output from the inverter is routed through the motorhome to a double socket into which we plug the desired item. We have a solar panel which puts some juice back into the batteries on sunny days and we find we can be 'off grid' as it were more or less permanently in the summer nor having to worry about power consumption.
An inverter can deplete batteries very quickly if left on so you need to make sure your batteries are in good condition and fully charged.
There are two types of inverter the standard one which we have and a 'pure sign' inverter which gives a steady and purer flow of power. Some sensitive laptops need the pure sign type but for us the ordinary one is fine.
As said there are many types and sizes, some may think my 1000 watt is overkill. However it only takes out of the batteries what it needs to power the item plugged in to it. I am sure others will tell you what setup they prefer.
IMPORTANT. The 230/240 output from an inverter, if handled incorrectly will kill you just as sure as your domestic mains at home. If you are not sure what you are doing, get a professional to install for you.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I wrote this document in 2009 - in the downloads section. It provides some background on inverters as well as describing how I fitted a small unit in our van. May be useful as an introduction.
Link Removed
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
Hi, why go fro 12v to 230v then back to 12v?
just get 12v adaptors for your device's. keep it simple:thumb:
Steve
43,319
49,372
sorry, completely incorrect.
A 1000watt inverter will produce a little over 4 amps @230v......1000w ÷ 230v = 4.347amps...
but at peak output it will consume 83.33amps from your battery........1000w ÷ 12v (nominal) = 83.33amps
In realty it will be higher due to electrical losses in the conversion from dc to ac volts, lost as heat which is the reason for inveters having a cooling fan, and is usualy in the region of 10% so could be around 92amps
Jan 3, 2008
3,337
5,356
Looking
Completely incorrect
Quite so.
The sentence, "I have a 1000 watt inverter which produces 83 amps, therefore I can run any 240 volt appliance provided it does not exceed 83 amps" should have read,
"I have a 1000 watt inverter which USES 83 amps, therefore I can run any 240 volt appliance provided it does not EXCEED 1000 WATTS" In other words I cannot use an appliance which would consume more power than the inverter is capable of drawing from the batteries. i.e. 83 amps
TheBig1
17,613
43,147
cheap leisure batteries dont like higher power inverters as they are designed for a steady lower current discharge. a 1000watt inverter will draw 83amps per hour, so flattening a leisure battery of say 100amp/hour in a little over an hour. this will then take several hours to recharge
using 12v chargers will use far less current from the battery and then allow it to recharge quicker
Oct 1, 2013
7,511
19,934
Lanzarote
Nil by mouth
Lots
I don't understand leccy, so will it draw 83 amps, no matter how much or litttle it's using ?
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
More like half hour or you deplete the battery's past the 50% drain kill limit :winky:::bigsmile:
This is now getting way past the keep it simple :Smile:
terry
funflair
19,326
30,156
Guisborough
MORELO palace
since 2012
We have a 2kw pure sine wave inverter running off 160ah battery bank, the pure sine wave runs a microwave much better than modified did and it runs the coffee machine and anything else that contains electronics where they would not run at all on the old modified sine wave. If we use 1kw for 10 minutes in the morning for coffee and porridge it only takes about 15 ah from the batteries so the solar panels can put this back in an hour or two.
Martin
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Have a 600watt non-sine wave Maplins inverter here if anyone is interested.
£30
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Hi,
Regarding inverters, I recently installed a 1500watt pure sine wave inverter. This is sufficient to power a normal hair dryer if just the first setting is used, it also powers a set of hair straighteners (not GHD brand, for some reason).
I have hard wired the inverter to the leisure battery via an inline fuse and a battery isolator which is placed adjacent to a 240v socket outlet connected to the inverter output, (both have been fitted into the seat locker base for ease of access).
The inverter works a treat, and fulfills my wife's only request for mains power for her hairdryer and straighteners when camping without EHU.
I would say that the power of the inverter required is down to the individuals needs, most appliances , i.e laptop, tablet etc will have a power rating on the label, it is worth edging on caution and choosing an inverter rated above that. Also worth noting, it is recommended that anything over 200watts is hard wired, some even state 180watts. Whatever you choose, the main thing to remember is to isolate it after use as they tend to draw sufficient power on standby to quickly discharge your battery.
I would also agree with the previous post that inverters do tend to 'hammer' your battery for power and would say they are okay for short periods of time. It is also worth considering solar panels in conjunction with the fitting of an inverter in order to give your battery chance to recover charge. I have put up 2x 100watt panels feeding the battery via a 30A mppt charge controller that keeps on top of things.
As mentioned in a previous post, charging phones and e-readers is better done with a 12v charger.
When you weigh up the costs it is purely down to the individual and their needs, if you want to have the freedom of camping without the necessity of EHU, its the way to go. So long as its combined with solar panels if you want power to last more than a couple of days. I'm just happy that I have the freedom to do as I choose, and of course my better half is happy. I hope this helps, if anyone wishes any further advise, detail or even photos, I am only too happy to help where I can.
PeterCarole29
1,120
1,148
Colchester
Renault Master Fleetwood
20 years
Hi,I am still in the process of the refurb of our van since we went to Malvern.My wife also had only one request.Hairdrier.I have fitted two traction 230ahr batterries with a pure sinewave 2500w inverter.Its a long story but thats what we have ended up with.
I dont know wether to get a battery to battery charger for £380 or solar panel
Any ideas please
g8ysn
638
417
ng219ep
coachbuilt
g8ysn
i have a 330w to power wife,s cepep machine, it will work of batteries but is 24v,so now use it via 3- 110 batteries through inverter,charge up via /genny 1k kippor,best for charging wife,s mobility scooter,scooter charger is 240 could i charge batteries [with appropriate charger] from leisure batteries,:RollEyes::RollEyes:
not technically minded any help appreciated:thumb:
camcondor
1,034
480
East Midlands
Small electronic gadgets don't generally draw a lot of electricity - there are small inverters you can plug into a ciggy socket, they fit into a cup holder and are quite neat -some even have a USB port that you can use to recharge USB fitted items. And they are inexpensive - about £20 or so.
