Inverters (1 Viewer)
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Looking at inverters I see there is a plug socket built into the unit itself.When used alongside leisure batteries and wired into the van are u able to use all the sockets in the van. Or do u have to run a lead back to the inverter and take power from that.
43,329
49,444
If the inverter is hard wired to the vans fuse/distribution box you can use all the sockets up to the inverters max output.
another wiring option would be a short hookup lead with a UK 3 pin plug on one end for the inverter end and then plug into the vans hookup point.
either way you need to turn off the onboard charger or it will hammer your battery.
Sep 26, 2010
611
364
North Wales
Hymer B654
Since 2009
Hi,
My advice would be to just use the one socket on the inverter, don't connect the output from the inverter into any other mains sockets in the van.
The inverter will be rated at 'x' Watts (eg 300W or whatever). Be careful not to exceed its rating. (Power = Volts x Amps). For safety sake, take advice if you're not sure.
John
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
We have 2 inverters, one 500 watt which supplies 3 separate sockets around the van which we never use, plus 1 X 3000 watt which has its own dedicated socket and battery which is charged by solar only when all other batteries are full. I never use the big inverter as I don't have enough hair to dry :Blush:.
haganap
12,759
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Simplest is to simply run an extension cable from the inverter to wherever you want in the van make sure it is uncoiled though :thumb:
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
It is possible to wire the inverter to the van's sockets, but not a simple job - you have to arrange for the normal circuits to be isolated. A job for an experienced auto electrician unless you know what you are doing. Taking the 230V output direct from the inverter is the easiest solution. If you want a more elegant solution than trailing an extension lead, have a look at the job I did with a 150W inverter. It's in the Downloads>Miscellaneous section. This link should take you to it:
Link Removed
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
I have a 1500 watt inverter
I have a 1500 watt inverter... fitted by VanBitz of Taunton.. a member on this site... All my 230v sockets are wired in and the batteries are powered by my 4kw generator on the RV...
I can power most things, like the air con (roof) microwave... mains 26" tv etc.,
I had a proper job done.. it was expensive, but well worth it... just wish I had gone for the higher rated inverter.... Mind you I do have a pure sin wav rather than a modified sin wave.. and they are not cheap.. but then I do not get tv flicker or lines and my laptops are happy as it is pure electric being used like in the house. I have two 100amp batteries and the set up works fine for me.
Bob:Blush:
Vlad The Impaler
Vlad The Impaler
1,633
2,227
Rutland
Inverter
When watching tv through inverter do lights in van still work have I got 12volt at same time
43,329
49,444
all 12v works as normal when running an inverter.
if your Tv has a 'black brick' in the mains lead it can also run on 12v with a 12v adaptor lead.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Lights , water pump etc all work as normal. But be aware what you take out of the battery you must be able to put back in it is a limited resource..
TheBig1
17,630
43,272
And dont forget to switch the inverter off when not in use as it will continue to drain your battery even with nothing plugged in
