Inverters
Discussion in 'Motorhome Chat' started by Hotelman, Jan 15, 2015.
  1. Hotelman
    Hotelman Funster
    Oct 12, 2013
    350
    403
    Filey
    SWMBO wants to use her 1750w hair dryer when not on hook up.
    An inverter seems the answer, and connected to the main battery, and then we can just run the engine for a few minutes when she's using it, we can also charge her e-bike battery when on the move.
    We have been quoted £450 plus fitting for a 'an all singing and dancing 2kw' inverter. He said we could find a cheaper one on the 'net' which he would fit, but obviously wouldn't warranty it.
    Help please, thanks.
  2. BreweryDave
    BreweryDave Funster Life Member
    Aug 10, 2011
    1,708
    3,905
    Torre Del Mar - Malaga
    That's a lot of dosh just to dry hair:eek:
    There are 12v dryers out there - probably crap but will get the job done?
    Alternatively - buy her a nice towel and spend the balance on beer :D
    • Like it Like it x 7
  3. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,206
    3,615
    walthamstow east london
    if you have to run the van to dry her hair you might as well go for a ride with her head out the window
    • Like it Like it x 19
  4. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,933
    12,188
    Plympton, Devon
    Someone can probably suggest alternative inverters but there are two main types, pure sine wave and not, so to speak, with a few shades in between. If you think you will want to run electronic equipment using the inverter then a sine wave inverter is what you need, but they are considerably more expensive. Worth checking what you are being quoted for. To just run a hair drier the square wave inverters will suffice but my only concern would be to run a 1750W hair drier a 2Kw inverter is going to be running more or less flat out. If for a little more money you can get a 2.5 or 3.0 Kw inverter things might be less fraught.
    Just remember a 1750W hair drier is going to be taking around 150 Amps at least from your batteries and just running the engine won't keep up with that sort of drain so you will need to ensure the batteries are fully recharged afterwards, which if you are off grid could take several hours. A B2B charger could be your next big investment.
    A pair of scissors and shorter hair is the answer - or stay on campsites with hair driers!
    • Like it Like it x 6
  5. scotjimland
    Jul 25, 2007
    28,935
    25,624
    what battery capacity do you have.. ? then do the sums..
    the drier will draw 145 amps .. so if used for 15 mins it will use 37 ah .. that's about half the capacity in an 80ah battery .. ie .. it's flat , dead.. no use..
    also, leisure batteries are designed to give relatively low currents for long periods... discharging rapidly and repeatedly will shorten it's life
    and as DBK said.. "just running the engine won't keep up with that sort of drain "
    • Like it Like it x 2
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,087
    17,751
    YO11 2BD
    No they won't.
    There are many long threads on the subject of 12v driers.
  7. ASel
    ASel Read Only Funster
    Oct 23, 2013
    32
    32
    Gretna
    All phones, computers, flat screen tvs and tablets run on DC via a transformer so they do not know if your inverter is pure sine or square wave.
  8. John Laidler
    Jan 9, 2013
    8,933
    12,188
    Plympton, Devon
    But the transformer might. As in all things there will be exceptions but there are applications where you need pure sine wave. For laptops etc the simplest answer is a 12v adaptor, the sort you would use in a car to plug into the cigar lighter socket. No inverter required.
    Unfortunately, my Olympus camera comes with a battery which can only be charged from a 240v supply, no one makes a 12v charger for it, so I am thinking about getting a small inverter. Just dragging my heels at the moment as the thought of spending money makes me feel feint. :)
  9. pappajohn
    Aug 26, 2007
    30,087
    17,751
    YO11 2BD
    It will if
    It will if, as the op said, the inverter is connected to the main battery and not the auxiliary
  10. scotjimland
    Jul 25, 2007
    28,935
    25,624
    missed the part about the main battery..
    .. but 145 amps from the alternator.. I don't think so..
    and risks not being able to start the engine..
    I rather have a flat hab battery as engine battery
  11. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,807
    11,877
    Taunton Somerset
    Inverters when used sensibly are a uesful part of the motorhome. With a decent charging regime of B2B and solar, and a good sized battery bank there isn't much that you can't do with an inverter.
    Just be aware that if you buy a cheap inverter from ebay that originates in China and it catches fire you'll have no back up or come back from the manufacturer, the same if it blows up your eBike lol
    Electric toothbrushes, Medical equipment and good coffee machines are the main reason we come across for needing pure sine wave.
    We've just been asked to tender for mobile laboratories for a local authority and the procurment officer didn't know the difference!
    My wife would simply refuse to go way in our motorhome is the use of a hair dryer wasn't available! So we don't see it as an option lol
    If your getting one installed, it is better to have it installed with a transfer switch, which is route your 13 amp sockets, for ease of use rather than having a "dedicated" inverter socket and having to trail extension leads around the motorhome
    Eddie
    • Like it Like it x 3
  12. C200JK
    C200JK Read Only Funster
    Dec 27, 2014
    963
    3,174
    Ireland / London
    Honda i20 generator.
    Even running genny at near 100% for prolonged periods is not recommended. Inverter will draw huge currents from battery at that wattage.
  13. joncris
    joncris Read Only Funster
    Jan 11, 2011
    1,101
    1,614
    Where it matters
    I have a USB cables for camera, video cam and iPhone which I often plug into (my when in use) laptop causing them to be charged
  14. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,183
    15,157
    Leeds the one up North
    A 1750 watt drier you say?. These usually have 2 or even three heat settings. My wife never uses the full heat, have you asked yours?
  15. scotjimland
    Jul 25, 2007
    28,935
    25,624
    .. as a general statement on inverters.. agreed.. I also had a similar set up in the RV with a large battery bank and Victron multi plus 1600 watt charger inverter
    but does the OP want to spend a small fortune for his wife to dry her hair.. or for that matter have the available payload ?
  16. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,336
    5,593
    Guisborough
    I would go for a pure sine inverter so you are future proof, at £450 I would suspect that this is, it needs to be wired as close to the batteries as possible with good thick cables, not sure which battery you are suggesting but personally I would be running from a couple of good quality leisure rather that the starter battery. My OH uses a dual heat/speed heat hair dryer on the lower setting so not 1750W and usually only for 5 minutes so takes next to nothing out of the batteries (1200W for 5 mins=9ah) and the solar can put it all back no problem (as long as there is a bit of sun) never need to run the engine and would not unless we were on our own. I would make sure that the inverter has a remote start/stop that can be mounted inside.
  17. funflair
    Dec 11, 2013
    5,336
    5,593
    Guisborough
    What price for a happy wife(y)
  18. Techno
    Jul 28, 2010
    14,183
    15,157
    And of course when these subjects arise (as often as gassing) I get to post my favourite
    [​IMG]
    • Like it Like it x 11
  19. scotjimland
    Jul 25, 2007
    28,935
    25,624
    she may be less happy when eddienobitz bill hits the carpet.. :ROFLMAO:
    • Like it Like it x 4
  20. funflair
    Dec 11, 2013
    5,336
    5,593
    Guisborough
    The one thing she doesn't mind and is quite good at is "spending money"
    • Like it Like it x 5
Similar Threads
  1. Brakers
    61
    1,830
