inverter
Discussion in 'Tech/Mech General' started by ukbill, Aug 9, 2014.
  1. ukbill
    ukbill Funster Life Member
    Nov 3, 2011
    4,999
    4,920
    benidorm
    can someone tell me the best distance to instal my inverter to the batteries i can put it directly next the them or i can put them around 2 mtrs away next to the solar control and the incoming mains
    thanks
  2. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    6,020
    12,192
    Kettering
    As close as possible to the batteries. The cabling from the inverter to the battery terminals needs to be as short as possible.
  3. keith
    keith Funster
    Aug 25, 2007
    3,289
    1,674
    Ecclefechan
  4. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,299
    3,104
    Kendal, Cumbria
    Any distance from the batteries is OK but the thickness of the cable required becomes impractical very quickly. Keep it next to the batteries & extend the mains from it to where you need it.
  5. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    You are deep into electric history here. In USA they used DC originally and had exactly the same problems, losses in the cables, so built loads of power stations all over the city.
    Then along came Tesla, with his AC distribution. Immediately high voltage AC solved the cable losses and power stations could be built outside the city.
    Plus ça change.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,264
    17,930
    YO11 2BD
    2 mtrs shouldnt be a problem, but you will need feed cables as thick as your finger at least depending on the inverters output wattage.
