inverter
Discussion in 'TV & Satellite' started by Wildbill, Jan 7, 2013.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,347
    13,199
    somewhere
    what size inverter to run 14" flat-screen TV and satellite receiver
  2. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    A 150W Maplin type should be ok.
    [​IMG]
    http://www.maplin.co.uk/150w-24v-inverter-228609
    These can regularly be had on "promo" for £20, the one I bought also had an USB power out socket as well..
    Does the TV not already run off 12v DC via a transformer, in which case you could connect it directly?
    ps note I attached the 24V link :Doh: It should of course be 12V....:Doh:
  3. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,347
    13,199
    somewhere
    i am a bit of a tight arse it normal domestic one :Smile:
    • Like it Like it x 1
  4. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    I also use 150W inverter to power TV, freesat box, DVD player, max draw on batteries in sat mode is only 4.75 amps so battery does ok for six hours a night, 80W solar puts most of it back in during the winter and all of it in the summer.
  5. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,655
    7,908
    Look on the back of your TV and it should have a label stating the amount of watts it uses..
    Something like a Sky receiver 12 -15 watts..
    My cheapo 16" LED TV from Asda mains only was 20watts.
    The 150 Inverter shown above is ample, I have one and use it for lots of things..
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,783
    6,293
    South yorks
  7. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,498
    1,355
    SW Northumberland
    A lot of supermarket and other cheaper brand TV's can easily be converted to 12vdc if you've got a friend or whatever into electrickery.:thumb::thumb::thumb:
    Then it would be even less of a drain on leisure batteries given inverters are at best only 75-80% efficient.
Similar Threads
  1. surfbum
    8
    331
