Inverter (1 Viewer)
ShiftZZ
21,383
84,568
Dark Side of the Moon
Got a small inverter I don't think that's it's a sine wave thingy but can I go ok up my laptop onto it to charge etc?
Simple answer ad I don't understand lextrissity etc.
DuxDeluxe
14,658
72,764
Planet Zog
A woosh bang van
since 2008
Here you go, Dave. Here is a larger inverter completely free of charge. Don't thank me.......it is all part of the service with "Help the Aged"*
*one small flaw in that, isn't there? You are younger than me.......:blush:
P.S. as above, it should be OK according to my brother who does this sort of thing
scotjimland
2,320
10,003
A Woosh bang
I use a 200watt Sterling PSW for charging my MacBook.. .. A quasi sine way SHOULD be ok .. but I won't risk it damaging the power supply unit
it's also used to charge camera batteries..
However.. for a laptop probably better with a 12v converter that plugs into the ciggy socket.. they don't make an Apple approved one for Macs.. hence the inverter..
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Nov 6, 2013
1,416
3,169
S. Ayrshire
The usual
Since the beginning
I tried a "faux" sine wave inverter on mine (Samsung Ultrabook) - wouldn't charge.
Bought a charger very similar to the one in the link provided by Snowbird - worked a treat
ShiftZZ
ShiftZZ
21,383
84,568
Back to inverters. Is there any reason why I can't install it in the garage under the bed, it's close to the boiler.
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
Don’t try to charge electric toothbrush with it as it will blow the charger, been there and done it, pure sine wave ok though.
John.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Dear Dai,
Don't you feel bad about this Daffid, but I think you should leave technical stuff like letric , to Lorraine.
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
The benefit of having an good (pure sinewave) inverter.
You dont need to go out and buy yet another set of adapters for all your Tech
You can charge electric toothbrushes
You can use GHD tongs
You can make the most of your solar panels
They have a low battery warning
You can run devices that are higher wattage than your 12v sockets will take
You dont need to worry about cheapo 12v cigar sockets over heating.
You can have a long 240v lead from the inverter and not worry about voltage loss like on 12V
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Most modern laptop power supply/charger units are the switch mode type, which may buzz a bit on a modified sine wave inverter, but are genarally happy to accept pretty much anything you throw at them.
Check the input voltage. If it says 110 - 240V AC (or thereabouts) then it will be switch mode. If it says 220-240V, then probably not.
Snowbird & Jezport are both correct. Which answer is right for you depends on your personal circumstances. But you already have your inverter & you want to charge your laptop now. So the answer to your immediate question is 'Yes, if it's switch mode'.
