Inverter (1 Viewer)
Nov 2, 2014
1,086
1,012
somerset
coachbuilt
Hi guys my wife has got really bad copd, what size inverter could i run off cigarette lighter to run her nebulizer thanks in anticipation regards steve. Any aadvice would be taken in
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Inverters that are suitable for a cigarette lighter are recognisable by having a suitable plug to fit and generally are limited to 150 watts without connecting direct to the battery.
One example
Broken Link Removed
scotjimland
2,324
10,060
A Woosh bang
Check the wattage of the Nebulizer, according to Google, typically under 100watt , but do check ..
To be safe I would buy a pure sine wave, the one Techno pointed to is a Quasi sine wave.. it may work perfectly well.. or it may damage the nebulizer..
As it's an electronic device, I would play safe and buy a pure sine wave.. the smallest one I know of is the Sterling 200watt which I have just bought for charging Macbooks... it comes with a ciggy plug .. this is it http://sterling-power.com/collections/inverters/products/pro-power-sb-pure-sine-wave-inverters
If you decide on this they can be found a bit cheaper ..
I bought mine here http://www.sp-shop.co.uk/Sterling-P...B-charger-with-Cig-Connector-PN-SIB12200.html
Reactions: DBK
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
If you are going to run it off a cigarette lighter socket it would worth finding which fuse it uses and where the fuse is - and then carry a couple of spares. I have a little inverter for charging my camera battery as you can't get a 12 volt charger for it but it blew the fuse recently - which shouldn't have happened, but it did.
scotjimland
2,324
10,060
A Woosh bang
Macbooker
Broken Link Removed
Saw the Mac charger, also on Amazon, but have read reports of blown Macs using 1/3 party adapters .. but even if no bad reports, if used it voids the Mac warranty , no way would I risk it with a £1500 MacbookPro .. and a £1k Airbook ..
The Sterling will also be used to charge Camera, and video camera batteries , four in total .. + 2 Macs..
I have hard wired mine direct to the battery ..
