Inverter
Discussion in 'The Beginner' started by pamie, Feb 25, 2015.
  1. pamie
    pamie
    Aug 10, 2014
    171
    95
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,525
    12,682
    Bolsover, Derbyshire
    I will await more technical / knowledgeable replies, but I don't think it is anywhere near big enough for a coffee maker let alone a kettle
    It will all depend on the rating of your appliances, but a 1Kw kettle is very small, much better to boil on hob with conventional kettle, you cant beat a nice whistle
    Coffee makers I am not so sure about the watts
    But I will watch for other answers as it is one of my next jobs to sort (y)
  3. pamie
    pamie
    Aug 10, 2014
    171
    95
    my coffee maker is 1710w kettle is 900w i would not have them on at the same time
  4. scotjimland
    Jul 25, 2007
    28,934
    25,589
    before advising.. what size leisure battery(s) do you have.. ?
    the reason I ask, each kilowatt , (1000 watts) of power at 23ov will consume 84 amps from the battery.. so an 85 ah battery would be effectively flat in less than 30 mins.
    So unless you have a big bank of batteries and a way of recharging them .. ie solar panels or a genny.. use gas for everything you can.. leave the battery for essential stuff like lights and water pump.. and the TV
  5. pamie
    pamie
    Aug 10, 2014
    171
    95
    what does the 2000w peak mean ?
  6. pamie
    pamie
    Aug 10, 2014
    171
    95
    we have two leasure battery's top up by solar panel
  7. pamie
    pamie
    Aug 10, 2014
    171
    95
    we also have a genny under the van run from the gas if ever needed to top up but never used it never needed because we have always been on site just thinking about if we wanted to go on a site without elec for a night
  8. funflair
    funflair Funster Life Member
    Dec 11, 2013
    4,892
    5,155
    Guisborough
    I would say not big enough at 1000 watts, 2000w peak means that is the maximum it will supply that's just to get something started.
    I would go for 2000 watts continuos but also pure sine wave as I found the microwave more efficient and the Nespresso coffee machine will not run at all off modified sine wave.
    I would say that as long of you have at least 200ah of decent batteries you should have no problem, yes 1000 watts at 240 volts might use 85 amp but the equipment you have suggested using would only be on for a short time so a decent solar panel set up should keep on top of it, sun permitting. We only have 160ah of Gel batteries and 320 watts of solar and can use hair dryer, microwave coffee machine and microwave for a total of around 10 minutes so only taking 20ah out of the batteries so solar charging st 10 amps can soon put it back.
    I think a decent set up, and it must be fitted properly will certainly not come cheap but we think it's worth it.
    • Like Like x 3
  9. Sidney
    Sidney Funster
    Jan 27, 2013
    1,175
    749
    Stamford
    £75 what could go wrong?
    Well quite a bit actually. Kettles start at 600 watts and go through to 3kw, coffee-makers are typically 600w - 1200w.
    600w is likely to draw 60+ amps from the battery and any poor cables, crimps or connections (crocodile clips etc) can get rather hot if they aren't up to the job.
    Then you have the quality of the inverter itself to consider. Let's put it this way - I'd wouldn't leave this one unattended.
    Whistle kettles and stove top coffee makers take a little longer but you don't need to rush when you're in a motorhome.
    So just because you can, doesn't mean you should.
    • Like Like x 3
  10. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,071
    6,618
    Spain for the winter
    By coincidence a few Funsters and I tried an experiment with my Nespresso machine in a Morocco a couple of days ago. Here is the result -
    Our 1000w modified sine wave inverter ran the machine but it kept pulsing instead of running smoothly.
    Canopus's 3000 watt modified inverter ran it well with no problems.
    Suggy's 3000 watt inverter wouldn't run it at all, it didn't seem to recognise the power demand from the machine.
    A few things we have learnt this trip is that our 1000w modified sine wave runs my 800w hair dryer just fine, does not run the coffee machine very well and kills toothbrush chargers stone dead! :crying::doh:
    Anyone got a pure sinewave inverter for sale, 2000w or more?
    Anyone want to buy a 600w and or a 1000w modified inverter?
    • Like Like x 3
  11. pamie
    pamie
    Aug 10, 2014
    171
    95
    think i may just leave the inverter and stick to elec sites plus dont want to spend a fortune on one the van is all set up for an inverter two sockets all wires in place done by prev owner dont think i will ever get off road camping or just for a cup of tea if i cant convince the husband that we can sustain ourselves
  12. UK Pete
    UK Pete Read Only Funster
    Jan 16, 2014
    285
    334
    kent
    I had this dilema, in the end i opted for a stove top peculator for the coffee , and a double skillet for a small oven which solved the problem very cheaply, if i was going down the inverta route i would have at least 400ah battery bank and a bloody good means of replenishing the batteries
    pete
    • Like Like x 4
  13. pamie
    pamie
    Aug 10, 2014
    171
    95
    well thats it then if it wont run my Nespresso electric sites only !!!!!
    • Like Like x 2
  14. pamie
    pamie
    Aug 10, 2014
    171
    95
    I just had a look at the battery's 2x 110ah not enough then
  15. scotjimland
    Jul 25, 2007
    28,934
    25,589
    good decision .. (y)
    While off grid, my maxim has always been to try and use as little 12v as I can.
    LPG is the main energy source.. cooking, water heating, space heating, coffee making with a peculator or French press if you prefer.. makes wonderful coffee.... you really don't need that much 12v power, an inverter is like a black hole for 12v energy..
    in our early days of campervanning we didn't even have a leisure battery, the minimal needs were supplied by the engine battery,.. an early 70s caravan didn't have ANY 12 v ..it had a gas light, gas catalytic heating, gas fridge and a Whale foot pump for water.. never gave it a second thought..
    • Like Like x 4
  16. scotjimland
    Jul 25, 2007
    28,934
    25,589
    your choice.. it's still a finite resource and depends how long you want to be 'off grid' and not run out of power.. you need to do the sums.
    1kw uses 84 A .. you have 2 x100 =200 .. but you can only use 50% = 100ah
    but as said.. you will also need a pure sine wave of at least 2kw .. not worth it just to make coffee when there are good alternatives .. peculator, French press or Espresso machine.. all on gas
  17. pamie
    pamie
    Aug 10, 2014
    171
    95
    Thank you all for the info you have me convinced i dont need one
    • Like Like x 3
  18. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    i will ask my brothert for you i know he has a couple not sure of size they come out of mess vans that he has sold
    • Like Like x 1
  19. scotjimland
    Jul 25, 2007
    28,934
    25,589
  20. Armytwowheels
    Aug 10, 2012
    4,071
    6,618
    That would be great, thanks.
Similar Threads
  1. RS SPIKE
    25
    994
