Inverter noise (1 Viewer)
3
34127
Inverters work at high frequency and sometimes can sound noisy. It is usually caused by the transformer windings if they have not been properly encapsulated or if the transformer housings are not securely fixed to pcb or chassis of equipment.
43,323
49,437
Agreed with gozomike.
Once the voltage drops below a preset level the low voltage alarm will sound.
The higher the load via the inverter, the lower the available voltage regardless of the batteries off load voltage.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
To return to the original question from gozomike, how long and thick are the cables between inverter and battery(ies)? Also, what load are you drawing from the inverter (in watts) and how big is/are your leisure battery(ies)?
makems
3,440
27,697
Ingleby Barwick,,Teesside
Sadly had to give up
Some inverters have a fan to cool them when under heavy load (ours does) could this be the source of the whining noise?
Happycampers1
Happycampers1
71
29
St Leonards, Hampshire
Swift Kon Tiki 665
Newbie
Thanks guys. The leisure battery is new "apparently" but as it is under warranty the dealer is going to replace it. The cables are the correct size and only about 12" long. I think it must be a low voltage issue as it is fine when the engine is running.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Or, maybe there's a mouse inside?
Cheers, Dave(y)
