Inverter leads
Discussion in 'Motorhome Chat' started by PJGWiltshire, Mar 14, 2015.
  1. PJGWiltshire
    PJGWiltshire Funster
    Mar 11, 2013
    265
    166
    Hornchurch
    About to install a 1500W inverter. All going well until I have been forced to secure it about 1.25 m from batteries. The leads that came with the inverter are now to short. Some advice from you experts would be most grateful . Am I correct in working out that I now need to run the cable in a thicker grade as the distance from the batteries has now increased. If that is the case would 8mm thick be ample
  2. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    No it wouldn't!
    Your inverter is rated at 1500 watts, that would normally be a constant rating. You should assume double that for peak current.
    An inverter is also rarely more than 90% efficient, that means you should add 10%. Therefore you should calculate peak current for 3300 watts.
    At 11 volts, the voltage your batteries will be at under heavy load, the DC current could be as high as 300 amps!
    This is a worse case, but 35mm cable would be a safe bet, given the length required.
    I reckon you would be OK with 25mm though.
    • Like Like x 1
  3. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    723
    4,154
    Chelmsford Essex
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,185
    14,958
    Leeds the one up North
    I expect the OP means 8mm diameter which is not a recognised way of sizing cable in relation to current carrying capacity. John is referring to 25mm cross sectional area of the copper conductor.(y)
  5. PJGWiltshire
    Mar 11, 2013
    265
    166
    Hornchurch
    Thanks for your help, have also tracked down an old post where Andy states 35mm, so I will go with that. I have worked out the fuse as 125A (1500/12v) would this be be suitable or should I get a 300A mentioned by John
  6. Techno
    Jul 28, 2010
    14,185
    14,958
  7. SUGGY
    SUGGY Funster Life Member
    Nov 23, 2011
    904
    1,642
    scunthorpe
    My inverter is 3kw peak 2.5kw constant running ,
    i conected it up using 100 amp unipren cable .
    When using the Remoska it takes around 50 amp from the batteries ,
  8. PJGWiltshire
    Mar 11, 2013
    265
    166
    Hornchurch
    Many thanks Andy and everyone else. Shall get on and order.
  9. rapido convert
    rapido convert
    Feb 26, 2015
    58
    113
    knutsford cheshire
    Hi, i use heavy duty jump leads to connect my batteries and inverter, it is much cheaper to buy a set off fleabay then cut the clamps off, the last set i purchased were 30mm copper and 2.8 meters long they cost £14·00 delivered, ps my inverter is 2000w /4000w peak power pure sinwave and is 1.5 meters away from the lead battery in my battery bank.
    This set up has served me well without over heating /power loss for many years i have a 1kw solar system and only camp without hook up.
    Andy.
    • Like Like x 4
  10. Techno
    Jul 28, 2010
    14,185
    14,958
    I use the Blue sea brand fuse holder, very substantial quality kit.
    [​IMG]
  11. Techno
    Jul 28, 2010
    14,185
    14,958
    [​IMG]
  12. Techno
    Jul 28, 2010
    14,185
    14,958
    [​IMG]
  13. PJGWiltshire
    Mar 11, 2013
    265
    166
    Hornchurch
    what is the switch over junction for
  14. Techno
    Jul 28, 2010
    14,185
    14,958
    300amp isolator
  15. PJGWiltshire
    Mar 11, 2013
    265
    166
    Hornchurch
    Everything ordered, should be here midweek. Looks simple enough to clip together and the photograph guide is a dream. Is that four(4) batteries I can see and are they the cables for the solar panel
  16. Techno
    Jul 28, 2010
    14,185
    14,958
    yes
  17. PJGWiltshire
    Mar 11, 2013
    265
    166
    Hornchurch
    looks very tidy
  18. Steve
    Steve Funster Life Member
    May 8, 2013
    1,563
    1,837
    Compton Berkshire
    25mm ok but 35mm better.
  19. PJGWiltshire
    Mar 11, 2013
    265
    166
    Hornchurch
    Looks like I have made an error when buying the inverter. Checking it again I now note that it is a duel supply type. Not sure why this is so. Is it a case of running a positive and negative to both terminals from the battery or can I go through a junction box for both + and -, with one single feed to the battery via a 200A on the + (Intend using 25mm2 (230A) cable and Isolator.
  20. Techno
    Jul 28, 2010
    14,185
    14,958
    Picture?
