Inverter Fitting
Discussion in 'Tech/Mech General' started by JanGar, Jun 30, 2016.
  1. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    Hi All,
    I would like to fit an an inverter, 1000w, is there any info on this kicking around that would help me out? Wiring sizes, connections etc?
  2. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,182
    1,334
    Fareham, Hants
    • Like it Like it x 1
  3. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,157
    1,259
    Dronfield - Derbyshire
    • Like it Like it x 2
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,336
    5,593
    Guisborough
    Have you decide what you want to run off the inverter, do you want all your 240 sockets and appliances to run (excluding battery charger) or just a couple of dedicated ones.
    On the 12 volt side 25mm squared should be OK, keep the cable run to a minimum and make sure the fuses are big enough, i would say that unless the inverter is easy to get at make sure you get a remote start/stop.
    Martin
  5. Baycott
    Baycott Funster
    Nov 6, 2013
    6,452
    12,900
    East Sussex
  6. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    Thanks for your reply. I'm thinking it would be good to power all the sockets although I won't need them all, just a bit neater not having cables over the floor. Is it a remote control start?
  7. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
  8. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    Yes that would be a good idea, thanks for the information. Thinking just tv At night, wife's straighteners during the day And microwave occasionally.
  9. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    • Thanks Thanks x 1
  10. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
  11. funflair
    Dec 11, 2013
    5,336
    5,593
    Guisborough
    I think as soon as you say straighteners (hair I guess) I would say go pure sine wave inverter.
    Martin
  12. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    Yes I decided that would be the best choice. Thanks
  13. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,157
    1,259
    Powering the micro wave could be a problem with only a 1000W inverter. Many take 1200W
    What is the wattage of the hair straighteners?
    A 1000W is the best part of 100A!
    Best advice is to avoid anything with elements on inverters
  14. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    First thoughts are: straighteners 120w, micro 600w. They won't be on at the same time TV will be 12v
  15. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    Read that trying to choose the right size is important so trying to keep size low without compromising what's going to use it.1200 would do too just trying to keep it small as practical but open to advice. Thanks
  16. funflair
    Dec 11, 2013
    5,336
    5,593
    Guisborough
    Quoted post abbreviated.
    Good point(y) just go for 2kw straight away, and then bump up the cable size as well, our 2kw runs on 50 mm square that equates to around 10 mm diameter.
    Martin
  17. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,157
    1,259
    Is that the output or the input. You'll need to look at the plate on the back.
  18. JanGar
    JanGar Funster
    Jun 13, 2016
    111
    37
    Fife, Scotland
    Good point I'll check it
  19. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,406
    12,383
    East Sussex
    Do you need an inverter at all?
    If the main requirement is for hair straighteners, why not consider a gas powered pair?
    Saves battery power for your 12v TV
    Also I think a microwave would soon flatten your battery.
  20. funflair
    Dec 11, 2013
    5,336
    5,593
    Guisborough
    Two good 110ah batteries will cope OK, you tend not to run a microwave for long so although the demand for amps is quite high but as it doesn't last for long the overall consumption is relatively low, a couple of solar panels can have it all back up sun permitting.
    I did say good batteries though.
    Martin
