inverter connection to battery. (1 Viewer)
Mar 24, 2010
1,073
765
stoke on trent
relay lwb pvc
6 years
Bought a 600 converter for the van.It has heavy wires to connect to battery.Is it best to wire permanently to LB(2x 110a + 80a solar) or fit a 12v plug to plug in when needed?Intend to use to charge laptop and possibly E-bike battery/fans.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
I have mine with fixed wiring and isolation switch. An inverter will use some power on "tickover" even if no power is drawn.
Dick
scotjimland
2,303
9,966
A Woosh bang
Best to hardwire to the battery .. I won't go into detail as there is well written and instructive guide by one of our members @JeanLuc in the resource section...
download here
http://www.motorhomefun.co.uk/forum/resources/install-a-small-inverter.17/
that is how I installed mine which is a 200 watt PSW
NB..the guide is for a 300 watt inverter.. consult the chart on the guide for cables to suit your 600 watt unit which draws 50amps
ie.. cable size is 25mm for up to 1.5mt length
2,585
8,773
Lincs
Globecar Campscout
Dick
Hardwire with a suitable isolator switch.
Are you suggesting an isolation switch in addition to the inverter's own on/off switch, or as an alternative, such as when the inverter itself is in an inaccessible position?
Glandwr
Banned
Jul 10, 2014
1,057
3,301
Hymer S740
since 2009
If its accessible buit in one is fine
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
only way to plug that in would be those plugs they use for jump starting cars whose name has escaped me
googles your friend they are called anderson plugs
