Inverter advise
Discussion in 'Tech/Mech General' started by pudseykeith, Aug 24, 2009.
  1. pudseykeith
    pudseykeith Read Only Funster
    Nov 5, 2007
    382
    105
    Leeds West Riding of York
    Hi Guys. Could I seek your advise re - inverters
    Q1. What size inverter would you recommend to feed a 230 volt transformer to give an permanent output of 1500 mV at 9 volts AC.
    Q2. What would the inverter take out of the house batteries to achieve the this.
    If not practical, is there a transformer that will reduce 14 volts [ fully charged house batteries ] to 9 volt AC
    Thanks guys in anticipation of your help.
    Pudseykeith :thumb:
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    Hi Keith I assume you mean 1500mA amps not volts which is 1.5 amps.
    which at 9V is 13.5Watts
    13.5W/12V =1.083R Amp the smallest, say 150 amp inverter will do you. and will consume around 1.5 amps in total
    A 110amp/hr battery has a useable capacity of around 55 amps for one hour so your conversion would flatten the battery (If nothing else was used) in around 36hrs.
    but of course there are others out there who know better who will come along and tell me I have got it all wrong.:Rofl1::Rofl1::Rofl1:
  3. pudseykeith
    Nov 5, 2007
    382
    105
    Hi Roger.
    You are right. Thanks for being understanding. We have3 110 amp batteries plus solar panels in the roof. I am not sure what they produce. The tech data is in German so find it difficult It states - Electr - 3.27A. Kennwerte - 53Wp. Leerlaufspannung - 21.8 V per panel. there are 2 panels.
    I am not sure what this will add to the battery state.
    Keith
  4. Wildman
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    you have plenty of battery storage to cope. The panels look to be a pair of 58W so could realistically be producing 2.5 -3 amp/hr max which will top up the batteries nicely if you get enough sun.
  5. pudseykeith
    Nov 5, 2007
    382
    105
    Thank you Roger for your help. Its much appresiated I will buy a 150 / 200 A inverter. Do you know were to go to get the best deal ?
    Regards, Keith :thumb:
  6. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Keith,
    Are you sure that you want ac and not dc if that's the case then.................
    I don't think you need an inverter at all, it sounds like you are looking to supply a 9 volt item of some kind that has a low power need, if so then what you want is a dc to dc voltage dropper ans there are plenty of these fitted into cigar lighter plugs.
    Doug...
  7. pudseykeith
    Nov 5, 2007
    382
    105
    Hi Doug
    I have not come across a voltage dropper. Can you explain, and where these are available from.
    Regards pudseykeith
  8. Wildman
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
  9. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    Ok, but first is DC that you want?? in your original post you said AC and AC at 9 volts is a very strange requirement.
    As to voltage droppers they are every where, the have them for almost every device that runs on battries. You probably all ready have one so that you can run something in yourcar, for example.. your mobile phone or your Tomtom. things like that.
    Doug...
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    yes roger you have got it all wrong mate.:Doh:
    what you mean is a 150WATT invertor:Rofl1:
    as you've been unwell i'll let it go this time only....watch your step in future.:BigGrin:
  11. Wildman
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    quite right John but then I just knew you would be along to correct me.
  12. pappajohn
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    :Rofl1::thumb:
  13. pudseykeith
    Nov 5, 2007
    382
    105
    Hi Roger
    Thanks for your help to solve my problem. :thumb:
    Best wishes, Pudseykeith
