Intro and a question
Discussion in 'Hymer' started by hallii, Apr 23, 2010.
  1. hallii
    hallii Read Only Funster
    Apr 23, 2010
    61
    Worcestershire
    Hello all, I am now the proud owner of a Hymer 522, I have just purchased it. I have been motorhoming for about 20 years.
    We go to France, Spain, Portugal, and other EU places for about 6 weeks at a stretch, this will be increased to a maybe 3 months on our next trip.
    Question:- my 522 is fitted with a swivel drivers seat, I find it a bit high and wonder if it can be lowered?
    I have found the "tilt" lever which doesn't really lower the seat.
    I wonder if I can take the seat off the swivel base and fix it as per the standard seat?
    I will, no doubt, have a few more questions in due time!
    Geoff
  2. Henryhymer
    Henryhymer Read Only Funster
    Nov 22, 2007
    64
    Hi Geoff. I also have a 522 which I've had for a couple of years. Being a short arse I don't find the seat too high but some time ago there was a thread on here voicing the same problem as you. Sorry I can't find the thread but hopefully the person who posted it will pick this up again.
    The tilt levers on my seat do lower it quite a bit but I have found you need to wriggle and fidget around a fair bit whilst sat on the seat with the lever pulled up in order for the seat to go down. So before any drastic action of removing the swivel it may be worth a good wriggle first.
    Best of luck with the van it's a good choice!
  3. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Hi and Welcome to MH FUN.
    It is possible to remove the swivel, this will drop the seat by aprox. 3 ins depending on make.
    You will find 4 poss. torx screws hold seat to swivel 2 front, 2 rear this will loosen seat BE VERY CAREFUL SEAT IS VERY HEAVY.
    Bolts found by sliding seat back and forward
    To remove swivel this is mounted 4 bolts again 2 front 2 back. back 2 normally mounted through slide rail.
    Fit seat to holes in base by holes swivel was mounted by.
    It is possible to get lower boxes to mount swivel on, but as battery is normally mounted below often entails repositioning battery.
  4. imprint
    imprint Read Only Funster
    Jul 14, 2009
    1,090
    11
    Can't help with the techni, Hallii, but welcome to the madhouse - you'll find it's just as useful for the serious stuff as the fun.
    Not all experts are drips under pressure - ours aren't!
  5. hallii
    Apr 23, 2010
    61
    Worcestershire
    Thanks Desco, I will get the spanner out and have a go, but before I take it apart I WILL have a good go with the lower/tilt thing and see if I can lower it that way.
    Geoff
