Internal fresh water tank drain valve
Discussion in 'Tech/Mech General' started by Caron, Mar 6, 2016.
  1. Caron
    Caron Funster
    Jan 29, 2016
    40
    120
    Suffolk
    Does anyone know where this is located within alan Autotrail Navajo? We cannot find it and my husband has been through the hand book with no success.
  2. trophychap
    trophychap Funster
    Dec 24, 2009
    730
    5,715
    bedworth warks
    On most vans its a sink type plug in the bottom of the tank, you will have to unscrew the cover on the top of the tank and fish about a bit. They often have a chain attached to them, presumably to stop them staying too far when they have been removed. Have never seen an automatic tank drain valve personally.
  3. Dorset Diver
    Dorset Diver Funster
    Dec 23, 2014
    397
    211
    Somerset
    If memory serves on AutoTrail there is a "tap" on the end of a pipe outside the van not dissimilar to the grey waste drain.
  4. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,701
    2,174
    Scotland
    It's probably on the same side as the waste water drain down. Blue circular "tap" with bar across it and drain outlet below.
    The tap and pipe assembly can, on occasions, come loose fairly easily as it's a push fit supported by a spring clip so may have detached?
  5. Caron
    Caron Funster
    Jan 29, 2016
    40
    120
    Suffolk
    Thanks for your responses we will check it out
  6. K9Brian
    K9Brian Funster
    Aug 2, 2010
    614
    610
    South Manchester
    Fresh water tank drain is behind the rear wheel on the drivers side clipped up behind the skirt. The heater tank is harder to find in the wardrobe under the false floor and right down behind the fire. Use a torch and look for the yellow valve - tip it vertical to open then open all your taps to drain down.
  7. Caron
    Caron Funster
    Jan 29, 2016
    40
    120
    Suffolk
    Great thankyou
