interior mirror/reversing camera fallen off
Discussion in 'Tech/Mech General' started by Welsh girl, Oct 9, 2012.
  1. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,708
    1,315
    living the dream.
    The interior mirror has fallen off and as the rear reversing camera is fixed onto it is fairly heavy, we have used double sided pads but it fell off again.:Sad:
    We have driven for a while using the side mirrors as we cannot see very well anyway through the van to the back window due to the bikes on the bike rack.
    But we think why have one if we cant use it!!:RollEyes:
    Any idea's of how to fix this back on permanently please?
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,337
    7,459
    Nr Watton in Norfolk
    You can buy a special kit from most motoring stores for refixing mirrors, but it is very important to follow any instructions to the letter or it will fall off again.
    The kit includes a special adhesive and a small mesh sheet and may have a means of cleaning the screen and back of mirror bracket.
    I would remove the camera screen to reduce weight until you are sure the bracket is firmly attached.
  3. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    a trick i used to use when fitting mobile phone aerials to car windows was to heat the base of the aerial with a hair drier then apply the adhesive to the base then heat the window with the hair drier but keep the base warm ( we used 2 hair driers ) then remove the backing and stick whilst warm.
    this is after cleaning both surfaces with surgical spirit although the kits will have alcohol wipes supplied with them.
    if you lightly rub the back of the mirror fixing with sandpaper then wipe with the alcohol wipe you will get a better fix.
  4. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    whats an interior mirror when it is at home?
    What is an interior mirror when it is at home?
    RV's use backup camera's and wing mirrors.. an interior mirror would only allow me to see Ezzie....
    Bob:Blush:
  5. Welsh girl
    Nov 7, 2009
    2,708
    1,315
    living the dream.
    We have a rear lounge so could see the road behind through the interior mirror if we didn't have bikes on the rack but as it also holds the reversing/backup camera, the mirror is just a holder really as the reversing camera clamps over the interior mirror.
  6. slobadoberbob
    Jun 1, 2009
    6,159
    1,970
    more clear now
    More clear now....
    Bob
  7. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    As mentioned before, the loctite mirror mesh is the best option. Once that sticks, it only comes off with half the windscreen attached!
    You can look at local car accessory stores or an auction site, should only be 2 or 3 pounds.
  8. tomm
    tomm Read Only Funster
    Mar 2, 2011
    262
    272
    uk
    Rear view mirror in my car came off. I tried the stick on pad things , they were hopeless, mirror vibrated like no ones business and constantly fell off again .
    Then went in to one of the national windscreen repair depots . Guy there fixed the mirror back on via whatever adhesive they use . He initially refused to take any payment as it was only a few minute job. I had to persuade him to take a few quid for his trouble. No problem with mirror ever since.
    Give one of the windscreen depots a try , am sure they would help out..
  9. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    If you mean fix it to the glass the front window....araldite two part resin glue....if it is to stick the part / clip that your mirror slides onto.... araldite...used it before, look for the 5 min quick set one..and just hold it till it goes off then leave for 24 hours.....Just a very thin layer of the mixed glue.... so it does not runs down the window...a warm window will help it go off quicker...in fact stick some masking tape or gaffa tape all around the area of the clip just leaving the glass showing for the part to stick onto...so none does go onto your glass:thumb.
    Used it myself on the front glass of our car, after the new one they fitted fell off :Doh: still there solid as a rock:thumb:
  10. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,824
    3,326
    Eastbourne East Sussex
    Surgical spirit contains an oil which may weaken adhesion. Best to use methylated spirit (the purple one, tho thats only an added dye of course):thumb:
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,936
    17,600
    YO11 2BD
    I used the 'loctite' kit a few times when working breakdowns....cant get much better if instructions are followed to the letter.
    you only get one chance to position it correctly so take your time...and dont let it move when in place, only take a few seconds to cure, or you get adhesive on the glass which wont come off
