Interference on TV from led strip lights
Discussion in 'Tech/Mech General' started by Nigel&Debbie, Sep 17, 2015.
  1. Nigel&Debbie
    Nigel&Debbie Read Only Funster
    Nov 20, 2012
    287
    206
    Full Timer
    when I turn on the two long led lounge lights in my Autotrail Dakota, I end up with interference on the satellite sourced drop down TV unit. Interference is also visible on the in built media unit screen. None of the other led lights interfere with the picture. Any thoughts on how I can stop the interference?
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,114
    17,785
    YO11 2BD
    A small ferrite ring or rod in the power wires may help.
    The tv may be picking up interference from the common power supply if the led strips are not shielded in any way.
    Electronics arent my field but i have seen ferrite rings used to good effect.
    • Like it Like it x 1
  3. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    dont get any interference from my gas lights . mind i do get some warmth and they kill flies and mozzies dont like them . plus they save more leccy than led,s .
  4. pappajohn
    Aug 26, 2007
    30,114
    17,785
    YO11 2BD
    I dont suppose the people living near the 1600 gas street lights still in use (2011) in central London get interference either Alan.
  5. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    cant be doing with all this modern stuff.
    mind we have got colour tv in cornwall now .
  6. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,891
    1,773
    Cornwall
    "mind we have got colour tv in cornwall now"
    Thats only because they were selling tins of paint cheap at Trewartha's. Ours is still in B &W.
    Safe travels Alan.
  7. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    now you should know you cant say that it could be racist.
    catch you in lidl .
    same time same channel. ha ha .
  8. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,192
    3,020
    Kendal, Cumbria
    On the + & - wires as close to the LED light as possible: 0.1uf capacitor across the wires then a couple of ferrite beads on each wire. Beads should be nearest to the light, Do this for each light and if the light fitting is metal connect it to the -ve wire.
    • Like it Like it x 2
  9. CandC
    CandC Funster Life Member
    Jan 22, 2014
    196
    331
    Cornwall
    Trewarthas are good, but I miss Doney and Hancock. Robert would constantly amaze me by climbing over and through his seemingly random assortment of "stock" to lay his hands on the most obscure items of hardware, even just going from a somewhat sketchy description!
  10. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,891
    1,773
    Cornwall
    We arrived more or less at the same time as they were shutting up shop.
    We built our house and it was a mine of useful stuff when you needed something, "NOW"
  11. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    you both lost me . i remember trago starting with what was only a market stall in glynn valley. ha ha .
    i must be the young one here . hee hee .
  12. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,760
    10,177
    I remember my dear old nan speaking to the TV repair man. He asked is it a colour set? No, said nan its in a wooden box:rofl::rofl:
  13. stevec
    stevec Funster
    Sep 24, 2013
    616
    207
    Norwich
    LEDs should not cause any more interference than normal bulbs. Unless they are being driven by an active dimmer circuit. These generate a square wave which can kick out all sorts of crud. More power efficient than a resistive circuit. Having said that it should be straightforward to try the solutions given.
  14. Nigel&Debbie
    Nov 20, 2012
    287
    206
    Full Timer
    It is on a dimmer circuit - the button is on the panel above the door. Will try magnet thing first
  15. bubble63
    bubble63 Funster
    Aug 10, 2012
    575
    531
    cambridge
    LED's do cause interference
    I had some bulbs from one of the show'regulars' not altern, but the ones from derbyshire;)
    Had to remove them, they disabled the DAB radio signal and the the TV, Some early bulbs didn't conform to regulations, hence they interfere
    Good suppliers = good bulbs
  16. Diabalo
    Diabalo Funster
    Oct 14, 2007
    2,001
    395
    Rochester
    Nigel are you sure its the lights as I have the same in my Mohawk but it only does it with the PSU on, no interference at all if I turn it off and run of the hab batt
  17. Nigel&Debbie
    Nov 20, 2012
    287
    206
    Full Timer
    It is the dimmerable lounge lights causing the issue as we even get it whilst off hook up. Turn the lounge strip lights off at the interference stops. Looking for a suitable magnet at the moment to see if this sorts problem.
  18. CandC
    Jan 22, 2014
    196
    331
    Cornwall
    independant hardware stores. Their selection of mainstream items such as lighting may not be quite as good as national chains, but they will often have some more obscure items and, when living in a rural area, can save you a long car journey. Any extra cost is usually offset by the savings in fuel.
    Like your local sub post office, use it or lose it!!!
  19. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    must say never been in them.
    never really shopped at callington .
    been there lots of times . used to work out of the sww sewage works there .
    learn something new every day.
    and i agree i use out local post office as much as i can .
