Interested in batteries (1 Viewer)
Braunston
1,408
7
Hi,
I found this link from another forum and I know nothing about batteries so it makes very interesting reading, well worth reading
Link Removed
hope that helps
davetthedon
141
Malvern, Worcestershire
GreatBig Bugger
Well researched sir....
A very interesting and informative piece, and in future years I will STILL be buying good old "lead/acid" batteries for my camper. :thumb:
I did think there was something fishy about these so called "deep cycle" batteries. My mother-in-law has just gone off the deep-end to buy some of these new-fangled coiley type thingys, two of which have just cost her an arm and a leg, just so she can watch TV for a few hours longer when un-hitched. :Doh:
I am on my third set of lead/acid now after 8 years. When I bought the van it had 2x85AH batteries, which I replaced when they died 3 years later (probably my own fault, I didn't look after them as well as I should have, ie top up occasionally, keep them charged etc). This time I have added another one, making 3 in series, because we now have CAMOS satellite, 2 inverters and all the add-ons.
Why 85AH? because Autotrail didn't build a tall enough battery compartment for a bigger AH battery set!! But you could get about 5 in a row. :Angry:
scotjimland
2,309
9,979
A Woosh bang
cheap FLAs are the best bang for your buck .. I've been preaching this for years.. refreshing to see a manufacturer agree
Conclusion
The best battery to use for fast charging using advanced charging systems
* For general leisure use: use low cost Lead Acid which can be topped up with water. So called leisure batteries
* For long term cruising then use 6 volt traction
Avoid Gel / AGM for 3 reasons
1. very expensive
2. their fast charger rate causes them to gas
3. poor cycling numbers.
45eEver
267
If you try this site, you'll get a similar but different point of view.
It has a very clear chart comparing battery types.
Link Removed
The general consensus of opinion in the trade is that semi-traction is probably the most costs effective buy.
You need a specialist battery place.
They are heavier than normal batteries, so it may pay you to support you battery compartment floor.
I sorted one a while back where the owner had found out the hard way.
scotjimland
2,309
9,979
A Woosh bang
I go by my own experience going back more than 20 years .. and cheap FLAs have never let me down. My present set of 4 x 85ah are almost five years old and three of these years have been full time.. and they often get a hammering, but still going strong... at a total cost of £120 they owe me nothing.
Of course they are properly maintained and kept in tip top condition with a Victron Multi Plus 70A 1600watt charger/inverter.
Spend cash on a decent charger and you won't need designer batteries..:winky:
barryd
1,143
109
Yorkshire Dales
Since May 08
This may sound like a dumb question but should I be regularly topping up my battery? I have had the MH a year now and it has a 110 AH standard battery which is quite well hidden. Never looked at it or done anything with it and we use it a lot. We had a new charger fitted recently but the chap that fitted it never mentioned anything, then again I never asked!
45eEver
267
It's worth checking the acid level in your batteries every so often Barry.
You may have a little sight doofer to tell you if you need to top up.
In my experience however, those little sight doofers are not that reliable.
About the only thing they tell you is if your battery is on the way out.
I do a caps off check on mine every so often, but haven't needed to top up in two years.
But only top up when your batteries are fully charged.
If you top up a flat battery, you will end up with weak acid.
If you use a hydrometer at the same time, you can tell the real state of charge.
If one (or more) of the cells is down on it's hydrometer reading, it's probably time to change batteries.
Many batteries you can't top up anyway.
It's worth checking to see if you have screw caps on your batteries.
H&SA reckon batteries can cause injuries, and you should wear chemical safety glasses and have a bucket of cold water around, plus lots of other tedious things I daresay.
Jim
Ringleader
Jul 19, 2007
36,403
130,782
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Saw a good tip the other day. Use a turkey baster to add the distilled water to your batteries whilst they are in situ, easy, no mess and you can add the precise amount. :Smile:
Kon tiki
487
North Wales
Low Line
My motorhome came with a 85 amp Exide gel battery, if I had to buy a battery I would go for a reasonably priced leisure battery. That said I have been impressed with how it performs but we would probably be classed as low power users. We have a suitcase type sat dish & only occasionally watch the tv, only have the heating on if it's cold, so our biggest use is probably lighting (have considered changing to LED but wonder if it would be worth the cost). We find that the battery is easily able to cope with what we use & I don't recall seeing the meter go much below 12.5 volts. We have a solar panel fitted (about 80/85 amp) & this has the battery charged up to 14.2 volts by mid morning or in dull conditions by the afternoon.
45eEver
267
I don't know what size batteries your turkey baster man uses Jim.
Or how often he tops up.
A hyperdermic syringe with a bit of plastic tube instead of a needle does the business pretty well.
Cheap enough to use a clean new one each time as well.
barryd
1,143
109
Yorkshire Dales
Since May 08
Thanks I will have a look. Vans in the garage at the moment having a service before our big trip. Just realised I had no idea when the Cam Belt was last changed so thats another £250 I didt think about!!!
T
The Meerkat
Hi,
Link Removed
hope that helps
Couldn't agree more, i bought an 1000 watt inverter from Amperor who supply the inveter range and had no quibbles at all with it
chris v
28
Burton upon Trent
Hi,
Instead of buying a Turkey baster just buy a hydrometer and suck the water out of the jar and squirt (carefully) into cells as required, you can then check th SG when you've finished charging. I always fill and empty the hydrometer a few times to flush it out in case of spillage from it,
Regards,
Chris
