Insulation
Discussion in 'Tech/Mech General' started by pablomc, Oct 1, 2010.
  1. pablomc
    pablomc Funster Life Member
    Apr 20, 2010
    860
    235
    Durham
    I have a service hatch inside the van for access to the fresh water tank, that I have noticed is a cold spot. On checking there is no insulation on it, so I am looking to put some insulation on the underside of the hatch.
    What is the best material to go for and best method of attachment? Would hate to use something that would then need replacing due to water ingress or mould. (Probably looking to cover an area of 60cm x 20cm).
    Also what is the best material for lagging external pipes?
    Thanks in advance.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,709
    17,324
    YO11 2BD
    closed cell foam sheet for the hatch.
    or just plain polystyrene.....its waterproof.
  3. artona
    artona
    Jul 31, 2007
    1,480
    690
    I would get a roll of loft insulation from B&Q and then seal it in polythene bags to make water proof
  4. artona
    artona
    Jul 31, 2007
    1,480
    690
    you will also find space blanket at B&Q which would do the job, its cheap as well
  5. pablomc
    Apr 20, 2010
    860
    235
    Durham
    Any particular adhesive recommended, or still not recommended?
  6. scotjimland
    Jul 25, 2007
    28,936
    25,589
    polystyrene for the hatch, use PVA adhesive
    and domestic water pipe insulation to lag pipes , IIRC .. comes in two internal diameters, 15 and 22mm , it's pre split for easy installation
  7. artona
    artona
    Jul 31, 2007
    1,480
    690
    just had another thought, if you can insulate the tank from the outside rather than stop heating reaching it from the van, the tank might freeze
  8. pablomc
    Apr 20, 2010
    860
    235
    Durham
    Good thinking. The tank has a heater, so I do not believe that will be an issue. :thumb:
