Instrument Panel
Discussion in 'Peugeot' started by Chrisy, Jun 24, 2015.
  1. Chrisy
    Chrisy Funster
    Jul 10, 2014
    121
    35
    Cheltenham
    Just wondered if we are unlucky or others have also had problems. In 11 months we have had 3 new instrument panels. We have had warning lights on for things like water in the fuel or bulb failure when cruise control is selected on. Sometimes more than one at a time. We'll see how this one lasts!
  2. Cal54
    Cal54 Funster Life Member
    Apr 25, 2014
    1,457
    9,089
    Lancaster
    Had very similar problem - whenever cruise was switched on I had 2 warning lights. Instrument panel replaced under warranty. My base vehicle is a Peugeot Boxer.
  3. rosalan
    rosalan Funster
    Jul 12, 2013
    882
    760
    Beds
    ....... in what vehicle?
  4. rickwiggans
    rickwiggans Funster
    Apr 2, 2014
    76
    56
    Lancashire
    Sounds like us. Just setting off for the ferry for last summer's trip, got water in the fuel filter and ABS failed warning lights, but only when the cruise control was on. 2015 X250. Luckily our Fiat dealer looked at it for us in double quick time, and confirmed it was the instrument cluster, not an actual fault, so off we went. Replaced when we got back 6 weeks later under warranty. Known issue. Our MH dealer says they know of quite a few. Fiat dealer said it first cropped up in Pandas. (Cars not bamboo munchers!). Also our friends with a new to them X250 based MH have just seen the problem.
  5. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,701
    2,174
    Scotland
    Our instrument cluster replaced under warranty for exactly the same issue on our 2013 X250.
    Main dealer mechanic didn't even get into the cab. Stuck the keys in, ignition on and 5 seconds later new cluster required see it all the time.
  6. Chrisy
    Chrisy Funster
    Jul 10, 2014
    121
    35
    Cheltenham
    Base vehicle 2014 Boxer
  7. mike13
    mike13 Read Only Funster
    Aug 13, 2014
    16
    5
    Tonight the brake fluid light is dimly lit, remaining on after ignition keys taken out.Peugeot boxer base, autocruise van conversion on a 2013 plate, does this sound like dash failure and if so would it be a warranty case?
  8. Cal54
    Apr 25, 2014
    1,457
    9,089
    Lancaster
    The warranty on Boxers is I Believe for 3 years, therefore a 2013 van will be covered. Sounds like the instrument panel but obviously need to look at the fluid level just in case. My vehicle is also an Autocruise but can't blame Swift for this fault!!!!
  9. mike13
    Aug 13, 2014
    16
    5
    Should have said level is ok, thanks for the reply.
