Installing Refillable LPG bottles in a Hymer B644
Discussion in 'Tech/Mech General' started by scotjimland, Apr 13, 2015.
  1. scotjimland
    Jul 25, 2007
    28,940
    25,628
    The gas locker is at the front below the passenger window (will post pics later) and as far as I can determine there is no place to fit an external fill point, my preference..
    The locker door hinges up.. complete with the plastic skirt.. so fitting there is not an option and there is no spare space at the side of the locker to fit on the body..I've concluded the only option is an internal fill point..not ideal.. but needs must.
    If you have fitted on a Hymer with the same locker, (I think they are all much the same up to around 2006 ).. would be grateful for an picture of the installation.. in particular where you fitted the fill point, and what kit you used, I think it can hold 2 x 11kg bottles.
    thanks
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    Isn't there a piece of skirt between the gas locker door and the belly locker?
    • Like it Like it x 1
  3. ASel
    ASel Read Only Funster
    Oct 23, 2013
    32
    32
    Gretna
    I see no reason why the fill point cant be in the door.
    Weather it opens sideways or vertically should not affect it.
  4. scotjimland
    Jul 25, 2007
    28,940
    25,628
    no Andy.. the whole skirt lifts up with the door..
  5. scotjimland
    Jul 25, 2007
    28,940
    25,628
    possibly an option.. but I've never liked the idea of a high pressure hose being continually flexed and also possibly being kinked and or damaged when opening/closing the locker.. so would rather fit inside..
  6. Techno
    Jul 28, 2010
    14,187
    15,162
    [​IMG]
  7. scotjimland
    Jul 25, 2007
    28,940
    25,628
    Yes, I looked at that idea but, the lpg hose and connection to the filler is inside the cab area..
    thoughts ?
  8. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    hya i have two large gaslow bottles fitted to my hymer i put the refill point on floor between bottles so to get to it lift up locker door drop flap its there nice and clean the gaslow kit came with right bracket easy to drill and bolt to floor
    • Like it Like it x 2
  9. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,388
    10,324
    Lorca,Murcia,Spain
    What about between the door & step in that small grey bit below reflector ?
    • Like it Like it x 3
  10. scotjimland
    Jul 25, 2007
    28,940
    25,628
    thanks.. that is what I had concluded was the best way..
    I don't like the idea of a gas hose and HP connection inside the habitation..
  11. scotjimland
    Jul 25, 2007
    28,940
    25,628
    it's just flimsy bit of plastic .. it would need to be reinforced..
  12. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,128
    8,360
    Forest of Dean
    Jim mine is identical and the external filler is fitted under the orange reflector on the skirt. Been there 4 years now and works perfect.
    Sorry cant take pic at moment.
  13. scotjimland
    Jul 25, 2007
    28,940
    25,628
    has it been reinforced with a plate .. ?
  14. s20hymer
    s20hymer Funster
    Jun 11, 2011
    274
    331
    Wiltshire
    p/s that was meant to read right angle bracket
  15. Manic
    Manic Funster
    Nov 4, 2011
    1,051
    1,181
    Uk
  16. Terry
    Terry Funster
    Dec 27, 2007
    10,770
    6,291
    South yorks
    Hi Jim put a bracket screwed/bolted to the side of the top of bottles and fit filler to that -Open door and filler is right in front of you
    terry
  17. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,929
    9,022
    Lincs/Cambs border
    Jim,
    Athough not Gaslow refillable cylinders, my bulk tank refilling point (square brass bracket with back plate) is positioned in the aluminium skirt, adjacent to the the tank. I have seen the round Gaslow filler connection in the same place on other Hymers.
    Cheers,
    Jock.
  18. Forestboy
    Jul 31, 2007
    5,128
    8,360
    Forest of Dean
    No
    I know where you're coming from I thought the same but its been fine for 4 year as I said and it gets a lot of use and I'm a bit heavy handed.
  19. Xabia
    Xabia Funster
    Jan 20, 2011
    776
    514
    Rural Nottinghamshire and Spain
    image.jpg Jim, I have a 2007 B544SL and the gas bottle layout seems similar to yours. The skirt is in aluminium and did flex a bit when the nozzle was connected so I stuck with Sikaflex aluminium angle to the inside of the skirt and wall of adjacent locker with another piece attached by bolts from one side to the other which formed a very rigid structure.
    Mike
  20. Forestboy
    Jul 31, 2007
    5,128
    8,360
    Forest of Dean
    Thats the same place as mine seen lots of Hymers with the filler there seems to be the most common location.
