Installation of electric plug outside (1 Viewer)
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
We have Bailey and the electric plug for electric intake is in the awning and we would like to put ordinary electric plug there and move our electric intake to other side of van
Any ideas how much a dealer would charge for this
Jul 13, 2008
3,738
3,860
Low profile
You want an electric "outlet" on the outside of your motorhome?
andy63
4,672
15,017
south shields
None
since 1990
Hi... I suspect that may cost quite a bit to have done by a dealer..
Do you have to move the original electric hook up point..
It would possibly be a cheaper job to just install an external socket and leave the hook up point where it is..
I fitted an external socket recently and think the box cost around 12/13 pounds and there was enough room to incorporate a 12v outlet on the same box..
If the new external outlet box fitted the ehu inlet hole that was left if you removed it to fit on the other side I suppose that would help..
A couple pictures of the outlet I fitted...
TheBig1
17,630
43,262
a dealer will charge way over the odds for such a simple job £100-200, but the outlet is under £15 plus about 4m of 2.5mm 3 core cable. you can reuse the original inlet on the other side. about an hours labour, maybe 1 1/2 cost depends who you use
if you dont feel able to do the job, a mobile caravan technician will likely be the cheapest and best ways to get it done
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Yes that's what we're hoping
We want to move the EHU point to other side of van and in its place put a electric point
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Will it effect warranty ?
Also we don't want to cut van ourselves
Feb 24, 2013
13,082
101,444
Bolsover, Derbyshire
Hymer S800
not long enough
I cant find it now but am sure I have seen an adaptor that fits into the inlet point giving you a 240V outlet
Can't really see why you would need to move it myself
andy63
4,672
15,017
south shields
None
since 1990
Hi David. . If you do that where do you get 240v from to power the socket.??
Edit... lol you are talking an additional fitting on themains inlet...
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
Bullfinch do one.
Enword
1,900
7,999
Devon
Coach Built
I use a 16amp fly lead.
Langtoftlad
8,861
150,762
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
What sort of socket do you want?
On behalf of the shy members of the NMC, I have to ask why you want to do this?
I'm sure its feasible but ensure its "weatherproof" (ip44?)
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
David I'm confused??
Do you mean one outlet does the both?
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Lol
I'm obviously not explaining this correctly ::bigsmile:
We have EHU on on near side of van, we want to move that to off side and put the electric Point in place if it??
It's cuz it's a Nusance in the awning and we want electric in awning so thought this might be answer
Feb 24, 2013
13,082
101,444
Hymer S800
not long enough
I am trying to find what I thought I had seen, but have been on the red for a while now :)
I am sure you can get an adaptor to plug either in line or into the normal connector on side of MH
but technically a 2 or three way adaptor would do it, then a short extension to the MH
provided it is inside your awning, some combination like this should work :)(y)
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Ah that looks good thanks
May 29, 2013
2,593
19,215
Tyneside
Chausson best of Flash 10
Several years now
Does having the EHU in the awning bit cause you problems so much that you want that out of the way ?
I'm guessing here, but do you want a household 240v socket under the awning area to plug an appliance with a square pin plug into ?
Unless you have a manky big battery bank feeding a manky big inverter then you'll only get 240v out of your skt when your on hook up, so I'd suggest the simplest way is some sort of splitter box off your 240v EHU input cable to supply whichever type of socket you require. BUT YOU'LL HAVE TO PAY ATTENTION TO WATERPROOFING OF WHICHEVER SPLITTER YOU GO FOR.
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
I sympathise with the op. It would drive us mad if the ehu socket was on the awning side. Nightmare!
It's going to be easy to move it though and having an electrical socket on your awning side will be very usefull.
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Since 2012
I've just made up a short EHU lead for when our van is in storage. On the female 3 pin socket that connects to the van there is Shuko socket on the back, would something like that help you ?
Bailey 15
Sep 18, 2010
1,093
1,716
Plymouth
Benimar 486 tessoro
2010?
Thanks SDC77
You understand thanku
I thought it was a simple question but seems not​
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
To put things in perspective our local dealer charges £75.00 an hour.
Mar 23, 2012
9,544
32,076
sleights
c class
Or just feed the cable under the m/h avoiding the awning and have an adapter
Jun 6, 2012
1,141
1,544
Leeds
Since 2012
Here is my solution, no need to cut any holes in your motorhome and easily transferable, just simply unplug hookup lead from motorhome inlet, plug into adapter and plug adapter into motorhome inlet and suction cup double adapter to side of motorhome (y)
Silver-Fox
9,266
29,081
Cheltenham Spa
Rapido
im a not so newbie
That's the way I would do it
Nice and simple only thing I would do is have an rcd on the 3 pin outlet just in case. I know the ehu has one but belt and braces :)
eddie
8,157
41,257
Taunton Somerset
RV
since 1989
:ROFLMAO: Seems a great way to get electrocuted
Your relying 100% on the supply being safe. On modern sites when things are inspected/checked regularly it would be OK many sites, often abroad, it would be dangerous
I sadly have seen many electrical setups where the trips have been bypassed, presumably by campers wanting unlimited power
We've even turfed off a bloke from our campsite for trying to change a MCB
He wanted a 32 amp one fitted, and tried to give me a "drink" to swap one over when I was repairing an adjacent power bollard that had been 'run over' that morning
I refused and told the wardens to keep an eye on him, and surprise surprise, a check a couple of days later he nobbled our system
