Installation of 12 volt socket
Discussion in 'Tech/Mech General' started by wiljoy, Mar 1, 2015.
  1. wiljoy
    wiljoy Funster
    May 23, 2008
    857
    940
    Crook, Durham
    I assume this question has been asked many times before.
    My vehicle has NO 12 volt sockets in the habitation area.
    I need one for charging various toys and am asking for your help please.
    The leisure batteries are only one metre from my proposed mounting area and the socket will only be used for light use.
    Many thanks in anticipation of help.
    Wilf
  2. andy63
    andy63 Funster
    Jan 19, 2014
    1,965
    7,158
    south shields
    hi, not sure what help you need but just decide on the type of socket you would like , ie automotive type or DIN, there may be others available but suspect the automotive type found in most cars would be the best. might as well fit a double while you are at it and select wires and fuse to cater for a 20A load even if you think you wont need it.
    you should be able to take it straight off the battery .
    ta andy
    • Like Like x 2
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,684
    11,798
    Plympton, Devon
    Consider fitting a USB socket rather than a cigar lighter type, unless of course you need one. Or fit both! I would fit an in line fuse, about 5A should be safe but ideally you want to feed it off a circuit you can switch off, not directly connected to the battery.
    • Like Like x 2
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,682
    17,298
    YO11 2BD
    Agreed with DBK...fit USB and cig sockets.
    my personal choice would be DIN, or Hella as they are also known.
    far superior to a cig socket and higher rated at 16amps but accessories dont usually come with them...prefering cheaper cig plugs.
    Cig sockets are fine for cig lighters but for accessories, in my view, they are dangerous.
    • Like Like x 2
  5. andy63
    andy63 Funster
    Jan 19, 2014
    1,965
    7,158
    south shields
    I fitted DIN throughout my van and for most things I use ie usb outlets and chargers I have to use an adapter anyway as that is the most popular plug . so the op will have to decide what suits best .
    for a single 12v outlet the simplest way would be off the battery and just pull the fuse if you need to kill the circuit, but again that will depend on the bother he wants to go to to fit it .
    • Like Like x 1
  6. sinner
    sinner
    Aug 19, 2011
    30
    31
    Scotland
    where would I get one like your pic?
    thanks
    • Like Like x 1
  7. John Laidler
    Jan 9, 2013
    8,684
    11,798
    Plympton, Devon
    Just Google: "12 volt USB socket" and you should find several. The prices have come down a bit since I bought mine. They come in different current ratings but this shouldn't harm whatever device you plug into it. If you can find one saying USB 2 this would probably be the one to go for as these have a higher current rating than the original USB sockets. The USB 2 and 3 standards are more usually used for higher data transfer rates but they also cover higher current output too - as a generalisation, 'tis a complex subject.
    • Like Like x 1
