Inline Fuse Holder (1 Viewer)
Darren
192
39
Canterbury Kent
Adria Izola
Can someone give me a link for a fuse holder that I should be using I between the controller and the battery please.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Darren
Darren
192
39
Canterbury Kent
Adria Izola
So does it not matter that the solar cable is a lot thicker than the fuse wire and how would you connect the solar wire to the fuse holder
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
The solar cable is larger to avoid voltage drop over a long run but its no so impotent for the short fuse cable. Of course both have to be able to carry the rated load likely to be used. The fuse cable is connected to the battery using a crimp butt connector on the end going to the controller and on mine the end that goes to the battery has a ring crimp connector as I have a bolt to put it on.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Feb 27, 2011
14,737
75,912
UK
Self Build
@Techno100 Just a quick question. Why have you got a fuse at the solar regulator end of the Cable coming from the solar panel?
I have a fuse up near the solar panels as that is the source of the current. On the output of the solar regulator I have a fuse at each end, one right next to the battery and one right next to the regulator as both can provide a current.
Just curious as to why this fuse (left one)
Techno
Jul 28, 2010
15,475
20,756
May 2010
It gives and easy means of isolation without tools and a handy way of connecting a blade fuse ammeter to corroborate readings.
I should add that these regulators don't call for any fuse at all on the solar side
Other options
Broken Link Removed
Broken Link Removed
Techno
Jul 28, 2010
15,475
20,756
May 2010
My own installation developed to a Maxi fuse on the solar as I prefer the large cable and a strip fuse holder on the battery side
