Injection system failure light
Discussion in 'Fiat' started by carken, Sep 2, 2013.
  1. carken
    carken Read Only Funster
    Sep 2, 2013
    32
    5
    Cwmbran
    Hi, I'm a newbie and sorry I haven't introduced myself yet but we've got a problem.
    We bought our 2008 Fiat Ducato 2.2 100 multijet based Swift Sundance 580PR in July. We left home today and noticed that the injection system failure light was on. I phoned our dealer and was told to take it in to be checked out.
    My other half has read something about unplugging the ECU and plugging it back in - does anyone know anything about this?
    Thanks in advance.
  2. Ed Excel
    Ed Excel Funster
    Nov 27, 2012
    869
    577
    Ribble Valley
    Our MH has the same engine. We learned from a Fiat agent, earlier this year, if the injection failure light comes on stop and start the engine four times, because there may not be a permanent problem. We had stalled ours earlier in the day and that, apparently, had caused the fault indication.
    Hope yours is as simple an issue.
  3. carken
    Sep 2, 2013
    32
    5
    Cwmbran
    Thanks for your reply.
    We've taken the van back to our storage farm as we're doing some building work at the house and there's no room for it at the moment on the drive.
    I read that dirty fuel might cause it and that could have been the problem as it was ok until we put fuel in yesterday - so he put some diesel injector cleaner in and run it for a few miles to the farm. We'll take it out tomorrow and hopefully that will have helped, fingers crossed.
    We only bought it end of July and haven't had chance to go anywhere yet.
  4. acting_strange
    acting_strange Banned
    May 16, 2010
    3,398
    2,568
    North Hykeham
    This light can be brought on by all kinds of things....the wiring to the injector will cause this problem....mine has been on for ages now but the van shows no signs of problems....do an internet search for ducato engine warning light and have a read...
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    dont forget....any warning lights on the dash which shouldnt normally be on is an MOT fail.
  6. acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    According to my test last week it only concerns certain warning lights....eg airbag etc...not engine...
  7. Larby
    Larby Funster
    Jun 17, 2012
    1,816
    4,168
    North Essex
    Red Light
    Most good independant garages will have a diagnostics machine. They won't spank you like a main stealer and you usually won't need an appointment.
    Their machine (usually Snap-On) will normally pin-point the problem and they can fix it cheaper than a main stealer as well!
    You can spend more money trying a fix than paying out for a diagnostic test.
    I bought my MH private (2.8, 2005 Ducato) Red light came on over 2800rpm.
    Diagnostics revealed turbo boost problem which translated as stuck spindle on waste gate. Fixed in 1 minute !! Vehicle had stood for several months near to the coast and spindle had seized.
    Good luck
  8. carken
    Sep 2, 2013
    32
    5
    Cwmbran
    Just googled engine warning light and there's a lot, isn't there!
    Hopefully ours will be alright when we check it tomorrow, we're hoping to get away in a few days time. Also want to go to the motorhome show next weekend.
    Thank you all for your replies.:thumb:
  9. pappajohn
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    the same light came on in my car a few weeks ago.
    it went into 'limp' mode....50mph max with foot to floor and erratic gear changes (automatic box)
    because of many known electronic problems with the Chrysler 300C i carry an OBD II diagnostic tool in the back.
    plugged it in and read the code, which indicated throttle control valve (the light doesnt mean injector fault, it means a fuel related fault).
    cleared the fault code and the car's run fine ever since.
  10. marjohn
    marjohn Read Only Funster
    Jun 25, 2013
    126
    58
    lowestoft
    hello there we have got i fiat ducato2.8 what they found was a wire broken under the engine that seamed to cure it wish you luck marjohn:Smile::Smile:
  11. marjohn
    Jun 25, 2013
    126
    58
    lowestoft
    hello there how much is obd11 diagnostic tool cost many thanks marjohn:Smile::Smile:
  12. carken
    Sep 2, 2013
    32
    5
    Cwmbran
    Just wondering, does anyone know where the ECU is on a 2008 Fiat Ducato 2.2. other half still wants to try unplugging then replugging it.
  13. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Any funsters in Cornwall, or visiting are welcome to pop round for diagnostics. On the basis that you come to me, it will be free!:thumb:
    • Like it Like it x 1
  14. Larby
    Larby Funster
    Jun 17, 2012
    1,816
    4,168
    North Essex
    It would be better to disconnect the battery and leave the lead off for 10 minutes. Just the negative lead will do, which is always first and last to prevent shorting the battery to ground
  15. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    585
    386
    Cotswolds
  16. carken
    Sep 2, 2013
    32
    5
    Cwmbran
    We've tried stop and start, hasn't made any difference, light's still on.
    We're insured with Safeguard and got AA cover so I've just phoned them and they're coming out to check it.
  17. rainbow chasers
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    It could be the injector loom being too short, which did plague that age. They susually extend it, it may be the problem - nothing wrong with asking the AA man to push it on a bit harder and see if it puts the light out. It may be something more serious - but worth a try.
  18. carken
    Sep 2, 2013
    32
    5
    Cwmbran
    Just did as you said, Larby, and disconnected the battery for 10 minutes and it worked. Thank you for that. I phoned the AA and cancelled so they didn't have a wasted trip.
    Thank you all for your help.:thumb:
  19. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,912
    10,285
    if the light comes back on again, get it checked as ignoring a fault could lead to more damage being caused.
    i too have an obd2 code reader which only cost £15 to reset fault codes and service indicator. however any code that comes back immediately indicates there really is a fault present
  20. carken
    Sep 2, 2013
    32
    5
    Cwmbran
    Thanks Big1, we'll keep an eye on it.
