Induction hob.
Discussion in 'Cooking in your Motorhome' started by Snowbird, Mar 27, 2013.
  1. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,236
    16,843
    Liverpool.
    I cant remember if I have given a revue on the Maplin induction hob, so if so I apologise. I bought one of these things some time ago as it was the ideal size for the van and I thought it would be useful when we have hookup. I can report that it is a great piece of kit and since arriving in Benidorm it has been in continual use and am amazed how quick it heats things up. Its so quick that when we return home it will come out of the van and be used in the house. One of my recommendations that will save you money when on site hookups. http://www.maplin.co.uk/2kw-induction-cooker-636623
    • Like Like x 3
  2. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    Valencia City, Spain
    I have a De Dietrich Induction hob in my kitchen and they are absolutely marvellous!
    The warning about not touching the hob whilst still hot is a little misleading as the hob itself does not heat up. Infact you can place a bank note on the hob and then place utensil and cook with bank note in between and no damage will be done to the note! The heat generated is from the food being cooked which transfers to the utensil. I was shown this by the guy who installed it.
    Incidentally, the best product for cleaning is a German make called "Froggy Vitro" which is also excellent for stainless steel. (http://www.werner-mertz.com)
    The following link will take you to the English version of the product:
    http://www.frosch.de/nc/main/produc...em]=60&cHash=66fa9b50828d753abfd5fda2fb060151
    Here in Spain you can buy it in Mercadona!
    • Like Like x 1
  3. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,853
    3,345
    Eastbourne East Sussex
    These are rated at 2Kw, i.e. 8amps approx. They cannot be used on most French sites which usually (the cheap ones we stay on anyway) are only rated at 4 or 6 amps.
  4. Snowbird
    Apr 24, 2009
    10,236
    16,843
    Liverpool.
    Am on 10amp hookup at the moment and have no problem having the induction hob on at the same time as the small electric travel kettle. I must add that the Maplin one is around the same physical size and weight as an average laptop. The thing is infinitely adjustable so am not sure if the 2 kw is on full power, maybe by turning it down a little it would not trip 8 amps. I agree with Momo that it cooks whatever is in the pan in seconds rather than minutes and as the cooking surface does not get hot in my opinion is ultra safe in the confined space of a camper.
    • Like Like x 1
  5. hilldweller
    Dec 5, 2008
    27,300
    26,280
    Macclesfield
    I don't like misinformation so.....
    No it's not, that's in a microwave.
    An induction heater causes huge currents within the steel pan which conducts electricity so it's a big short circuit and the metal gets hot.
    Don't believe me, put an empty pan on it.
  6. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    Didn't realize you are still in Benidorm Snowbird! Make sure to get some "Froggy Vitro" before you leave!
    My previous hob was natural gas which also gave good results but was a real menace to clean. This induction hob is not only easy to clean (seconds) but makes the best ever "Tortilla Española" and "Paella"! :thumb:
    • Like Like x 1
  7. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    Just re-read the Instruction book and it clearly states that cooking is by "vibration". I put an empty pan on but only able to ignite for 2-3 seconds after which it turned itself off, only remains ignited if food in pan. :thumb:
  8. olley
    olley Funster
    Jul 29, 2007
    3,779
    2,311
    Ipswich
    I am with Brian, its magnetic induction, that's why it won't work on brass, aluminium and some types of stainless steel pots and pans.
    Ian
    • Like Like x 1
  9. Snowbird
    Apr 24, 2009
    10,236
    16,843
    Liverpool.
    Thanks for the tip on the Froggy Vitro Momo. Have been down the market today and done my shopping but will be off to the Mercadona in Albir tomorrow to get some. It should be good to clean my Cramer ceramic gas hob in the van too. I had no idea what to clean that with before.
  10. Snowbird
    Apr 24, 2009
    10,236
    16,843
    Liverpool.
    As Olley states some pans will not work on it so we had to chop and change with some at home so as we only have ones in the van that will work on the induction hob. Whilst looking around a huge hardware store the other day I found what I think is a gadget to make all pans work on it. It looked something like a round flat tennis racket with a short handle. I will have to return with my Spanish dictionary to find out more. The only problem we have is the pressure cooker wont work on it as its made from aluminium.
  11. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    Hi Ian! I was just saying what the book says - I'm no expert! :Laughing:
    Can only comment my own experiences regarding daily use. Not the technicalities. :thumb:
    I had copper bottomed stainless steel pans previously but had to get all new for this hob. :cry:
  12. Spacerunner
    Spacerunner Read Only Funster
    Apr 7, 2008
    609
    195
    Hampshire
    Buy suitable saucepans from Tesco's value range, most are less than a fiver.
    The hob also makes a good electric BBQ for cooking outside, perfect for fish and other strong smelling food.
  13. hilldweller
    Dec 5, 2008
    27,300
    26,280
    Macclesfield
    That will completely defeat the efficiency of the induction concept, the "wires" will glow just like a normal element and the heat will escape all round the pan as usual.
  14. hilldweller
    Dec 5, 2008
    27,300
    26,280
    Macclesfield
    You are now.
    • Like Like x 1
  15. hilldweller
    Dec 5, 2008
    27,300
    26,280
    Macclesfield
    Now that is interesting.
    These things have very cleaver protection circuits otherwise if you brought you hand near and was wearing a ring, even gold because it's a conductive loop, you'd lose a finger.
    But you've got me stumped for now, I do not know how it knows that there is no food in there. I'd take a guess it can measure the temperature of the pan and it sees the temperature rising so fast it works out that there is no food in it.
    Here's a good read.....
    http://en.wikipedia.org/wiki/Induction_cooker
    • Like Like x 1
  16. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    You can get some anti-scratch scouring sponges in Mercadona which really work well. They are called "Estropajo Azul" with the words "No Raya" (3 pack) and you can really go at it without any fear of spoiling surface.
    Mine had a very dull, large area which I couldn't remove with any of the other cleaners but Froggy brought it back to shiney brand new with these sponges.:thumb: Incidentally, caused by using the gadget!
    Yes you are correct and it works quite well if you only have one or two rogue pans! (But don't get confused with another item which is popular here for making toast on a gas stove and looks similar but with a mesh base!) Just make sure it's big enough for your pressure cooker. Mind you if you wanted to get an induction one they are quite cheap here, mine is a stainless steel "Magefesa" which is a very popular make with the Spaniards.
    To check you could say:
    "¿Es para convertir sartenes para uso en placas de inducción?"
    (¿Es parra conberteer sartennes parra ooso en plackas de induc-thee-on?)
    (Is this to convert pans for use on induction hobs?) :Laughing: :thumb:
    They'll probably start babbling away at you presuming you speak fluent Spanish! :Laughing:
    Look forward to hearing how you get on! :Laughing:
    • Like Like x 1
  17. Momo
    Momo Funster
    Sep 19, 2008
    2,465
    2,997
    Very interesting read!
    This bit could be useful to Snowbird:
    "Induction disks are metal plates--much like a skillet with no sides--that heat up non-ferrous pots by contact, but these sacrifice much of the power and efficiency of direct use of induction in a compatible cooking vessel".
    I could add that they also spoil the finish/look of the shiney hob! (But only if you can't buy Froggy!) :thumb:
    • Like Like x 1
