I'm proper confused - Pilote G742
Discussion in 'Motorhome Chat' started by The Dude, Mar 26, 2015.
  1. The Dude
    The Dude Funster
    Jan 10, 2013
    2,305
    2,423
    Near Uttoxeter and Crete
    Just collected our new (to us) motorhome on Tuesday and we've spent the last 2 days on a very nice site in Woodhall Spa getting aquainted with it. The handover from the dealer was very rushed and this motorhome is very different to our last 2 so we are slowly finding our way around. However I just can't get my head around the AUX setting on the control panel. What does it do? Why won't the ignition on the hob gas burners work unless it is switched on? The ignition on the oven seems to work when it is not switched on. Also, the inbuilt Pioneer GPS/Radio comes on when the AUX switch is turned on. We've trawled the manuals but can't seem to find any mention of this.
    We're not very technical but have spent quite a while reading the manuals and are still baffled.
    By the way, I just love the Alde heating compared to Truma blown air - we were toasty even though the weather was foul.
    Thanks in advance.
  2. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,779
    11,988
    Plympton, Devon
    Aux normally turns on things like 12v charging points and in your case the hob ignition. That is how it should be - it allows you to isolate these electrical items for safety and prevent battery drain.
    I'm not sure about the oven, it might be pietzo-electric and not need external power.
    Is the GPS /radio on the dashboard? If so I don't think it should be wired to the Aux switch!
  3. The Dude
    The Dude Funster
    Jan 10, 2013
    2,305
    2,423
    Hi DB,
    Thank you for the quick reply and explanation. Yes, the GPS/radio is on the dashboard and it doesn't have a On/Off switch anywhere.
  4. John Laidler
    Jan 9, 2013
    8,779
    11,988
    Plympton, Devon
    That's weird but I guess it allows you to listen to the radio without turning the ignition on. I find it hard to imagine it doesn't have its own off switch. Can you identify the model or send a picture?
  5. pops
    pops Funster
    May 1, 2012
    419
    364
    south glos
    Our pilote panel van is the same. The aux switch will power the radio, we have not got a oven
  6. The Dude
    The Dude Funster
    Jan 10, 2013
    2,305
    2,423
    Hi Pops, thanks for your reply - was beginning to think we were losing our marbles!!
  7. Red Dragon
    Red Dragon Funster
    Apr 23, 2010
    647
    1,330
    Isle Of Man
    Hi Mark & Ann
    Congratulations on your new Moho,glad you got your problem sorted,now keep going and head for the hills,enjoy and safe travels.
    • Like Like x 1
  8. Zoppydog
    Zoppydog Funster
    Jul 19, 2013
    229
    182
    Suffolk
    Same on the Rapido, you need the Aux switch on for the Radio when parked up
    Chris
    • Like Like x 1
  9. Borderland
    Borderland Funster
    Nov 5, 2014
    433
    2,473
    Borders
    The radio may have an on off button but not marked as such. I have an Alpine radio and to switch it off I have to press, and hold for 3 seconds, the source button. May be worth trying this and also any other push button such as volume.
    • Like Like x 2
  10. The Dude
    The Dude Funster
    Jan 10, 2013
    2,305
    2,423
    Good suggestion. I will try this. Thanks.
  11. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,615
    22,788
    Narrfoook
    On rur Autotrail the AUX button just turns the external hab door light on, and the hob ignition is powered from within the main control box.. Though mine has been modified at some time to work independent of the rest of the gubbins
    • Like Like x 1
  12. sedge
    sedge Funster
    Jul 7, 2009
    4,568
    4,082
    Nr Jct 3 M6
    LOL - in our P716, two years later, I still try to put the kettle on sometimes before I remember to 'turn the electric' on.
    We have a 'French' bed which we normally use but also have a double bed over the dinette, which is electrically operated up and down. There was no plastic cover on the mattress thereof, hence we wanted to cover it, to stop it gathering dust in situ up there. Van parked at home ifn front of the house. Pete with king sized flat sheet in hand, gets in the cab, I go in the hab door at the other side of it and press the remote to lower the bed. Nowt. Pete and I both tried and tried and just about when I started saying 'Oh, we'll have to ring the dealers!' he suddenly remembered the Aux switch........
    Doh !!
    • Like Like x 1
