I'm finished with Rock and Roll
Discussion in 'Motorhome Chat' started by makems, Oct 18, 2012.
  1. makems
    makems Funster Life Member
    Sep 23, 2011
    2,647
    10,810
    Ingleby Barwick,,Teesside
    We had air suspension fitted to our Rapido at the Lincoln Show and WhAT a difference it has made. The Merc Sprinter chassis is so softly sprung at the rear that it would rock wickedly from side to side over even quite innocuous bumps. Going round a mini roundabout required the passenger to hold on for dear life to avoid being flung from his seat.
    Well no more! The airbags have made an amazing difference - one of our better investments.
    • Like Like x 6
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,179
    16,641
    Liverpool.
    I had them on my FFB, but none on the Merc 410 chassis. Have got a price to have the rear springs re tensioned and an extra leaf put in for £125 both sides, which is much much cheaper than the price quoted for air suspension. Its going in on Monday to my mechanic who will take the springs off and Jones Springs need them 24 hrs for the work. Hope this will stiffen her up a bit.
    • Like Like x 1
  3. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,536
    5,620
    Near Mold North Wales
    Fitted Air suspension to mine earlier this year and it transformed the handling.:thumb:
  4. Madmark62
    Madmark62 Read Only Funster
    Sep 28, 2011
    603
    552
    Wakefield West Yorkshire
    Got air suspension on ours and the ride is spot on. easily adjusted too.
  5. JJ
    JJ Funster
    May 1, 2008
    14,650
    25,993
    Airbag assisted suspension ROOLS OK?
    JJ :Cool:
  6. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    And people say the Fiat is too hard on the back but the merc is too soft
  7. champers
    champers Funster Life Member
    Mar 9, 2009
    3,478
    2,101
    Wales
    Which did you go for/ fitted by ??
  8. veevee
    veevee Funster
    Jul 4, 2010
    967
    541
    Essex / central France
    The usual rule is if you increase spring tension you must also increase damping too, it's a proportional thing.
  9. Snowbird
    Apr 24, 2009
    10,179
    16,641
    Liverpool.
    Am only bringing the springs back up to there original spec. The motorhome is now 22 years old and its a heavy body, so re tensioning is the answer. I have fitted an extra fuel tank on the opposite side to the water tank, so the extra leaf is to compensate for this and allow me to travel with full water tank.
    Have spoken to Jones springs of Darlaston who are well known and respected in the field of suspension and they have advised me this is the way to go in my situation.
    There is I believe only one air suspension kit in the UK at the moment suitable for this vehicle and the cost would be most prohibitive for the full kit, complete with gauges and pump. New shocs were fitted last year.
  10. veevee
    veevee Funster
    Jul 4, 2010
    967
    541
    Don't mean to be argumentative but you did mention an extra leaf in each spring on top of re-tensioning. That changes the rate of springing and shock absorbers have only one purpose, to control the spring rate.
    It was always match damping to spring rate, never worked to any other formula.
    Used to use Jones Springs a fair bit way back, a good company too, so am not going to argue against their advice.
    What was your view on air suspension on your FFB, did it work as you hoped?
  11. Snowbird
    Apr 24, 2009
    10,179
    16,641
    Liverpool.
    Hi, The air suspension on the FFB was factory fitted from new and was very good indeed.
    the problem with fitting air on my Merc is its now an old chassis and the units are no longer made for it. There are a few new/old stock units but they are not only like hens teeth they are well over priced. Will speak to Jones today and ask about your concerns as I want to get it right first time.
  12. Jim
    Jim Ringleader
    Jul 19, 2007
    26,143
    77,224
    Sutton on Sea
    We had AS Air suspension fit out our Hymer, We tow a heavy trailer and it made a big difference to the handling. When not towing we sit a little high at the rear so only have just enough air in to protect the bags.
    No matter how heavy the nose weight of the trailer, the raised suspension makes the trailer look empty. :thumb:
  13. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    When reviving springs, they are reheated and cooled under tension. This allows the metal 'crystals' to tighten back up from being stretched. Only down side is, that each time this is done is slightly alters the elemental make up of the metal, and thus changes it's character.
    This means that to reinstate the spring to it's original condition would be fine with just heating, but to maintain that strength and load carrying to original for a period of time, would need an extra 'fresh' spring to ensure it maintained shape better.
    • Like Like x 1
  14. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    NoJJ full rear air suspicion ROOLS OK :BigGrin:
    Terry
  15. makems
    Sep 23, 2011
    2,647
    10,810
    Our air bags were supplied and fiitted by Airride at Lincoln show Price was £520 which was a show "special" ( so he said). I asked him he had a good show - "Crap. He said. "Never gonna do it again ". It's the simple system with valves and pressure gauge in the ffotwell. None of these fancy compressors and dials on the dashboard.
  16. Paramotormanal
    Paramotormanal Read Only Funster
    Aug 29, 2012
    82
    56
    Kingston upon Hull
    Thank God for that!!!!!!! I thought you meant no more AC/DC or Deep Purple, phew :BigGrin::BigGrin::BigGrin:
  17. makems
    Sep 23, 2011
    2,647
    10,810
    Thank God for that!!!!!!! I thought you meant no more AC/DC or Deep Purple, phew [​IMG][​IMG][​IMG]
    • Those that know me well know that a Les Paul guitar and a loud amplifier will ever be far from my hands.
  18. Paramotormanal
    Aug 29, 2012
    82
    56
    Kingston upon Hull
    Spot on "Rock and Roll ain't noise pollution" I fly my Paragliders with it booming in my ears lol. :BigGrin:
