I'm an idiot - damaged new motorhome (1 Viewer)
adt
Mar 28, 2016
267
1,594
Cumbria
Nuevo
Since 2016
Had cause to be cursing youths who were partially blocking my route up our shared drive as I reversed up - I was looking too much at them and the trailer I was slaloming round and not at my slowly approaching motorhome in my mirror.
As a result, I reversed into my own motorhome. The impact was not enough to even wipe the dirt off the car but has resulted in this damage.
I'm struggling to find somebody that will do the repair in time for us going away on the 16th and was hoping there are some GRP experts out there to advise. I was considering stop drilling and just applying a bit of fibreglass repair kit to the rear side until I get home but in experience would it continue to crack ?
The rear metal support is bent here right behind the crack and I've moved it back forward to release any pressure on the crack.
Riverbankannie
10,432
60,972
Bristol
IH 630 RL PVC
Ouch, that is the most annoying thing to do to yourself. To say it could happen to any of us is of no consolation.
Hope you get it fixed.
irnbru
13,503
31,101
Glasgow
Benimar 264
11 yrs
Sorry to hear that but your not the first nor will be the last.
Looks as if it will be easy repaired if you take your time. And a lesson to be learned. I haven't made the same mistake twice and hopefully you wont either.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
I feel for you.... done some idiotic things whilst being distracted by my "head"...and EGO... :(
43,207
48,809
I would drill it for now at least.
As it will need flatting and painting for a lot more than the damaged area you could pop rivet a small metal plate on the back for now....rivets from the outside of course.
The repair should cover the rivet holes once removed.
Surprising how much vibration there will be on the loose bits.
Nov 6, 2013
1,403
3,106
S. Ayrshire
The usual
Since the beginning
Did very similar damage to ours - I think it was around £250 for repair inc respray
I wouldn't have minded, but the wife had already offered to get out and see me back. Of course being a bloke, I graciously declined her kind (but seemingly unrequired) offer of help. :whistle:
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
It doesn't need drilling (but it won't hurt it) as its already reinforced with random orientation glass fibre which will stop it getting any worse, if it's going to flap just put something behind at the bottom edge a bit of wood and drill through underneath and screw it.
Repair will be easy but could need paint really to finish it off, at the moment it will just be gel and no paint, a decent place might bo it with matching gel and rub back.
Martin
DuxDeluxe
14,628
72,241
Planet Zog
A woosh bang van
since 2008
Duct tape is a wonderful thing.
White is available for a temp repair.
Richard.
I would agree with that. Maybe a small stop hole at the end of the crack and cover it all with white duct tape. The less you do before a professional repair the better
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
Superglue a piece of plastic to rear, tempory clamp in place whilst set. Repair later. Picked this up watching builders fix facia trim, used to use nails, now use 2 part superglue.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
I agree with Dux, don't go glas sing the back as it will just make it harder to repair properly, I know you want it looking nice but it won't take any harm if you just put a reinforcing plate or something behind it.
Martin
Nov 1, 2015
370
682
Norwich
RAPIDO 686F
Just an addition. I've seen a spay used which is an excelerant ( speeds the setting process up ) spray on first, apply glue, push together and sets immediately. Think you should be able to get from any facia company. Goggle local firms or yellow pages
Ray
Feb 21, 2016
4,910
29,131
Uk
C class
Since 2017
Don't beat yourself up. I've reversed in to mother in laws nearly new car,a tree,and a white van,although not all at the same time. I'm OK going forwards.
Use duct tape for now.
Relax.
Jan 13, 2014
3,547
11,377
Leeds - Yorkshire
I wouldn't touch it, Please don't even consider Drilling/ Rivetting/ Clamping/ Glueing or any other temporary repair it will only make it more difficult for a professional to do a correct repair.
Fiberglass is extremely robust and though you've cracked it, it's very unlikely to get worse as it's not in a stress area and even if it moved a bit it's a lot less hassle to repair correctly without some botched up make good temporary repair.
So you have to drive with a bump on the rear! Who cares,just enjoy your trip and sort it when you get back.
Brian.
makems
3,435
27,584
Ingleby Barwick,,Teesside
Sadly had to give up
We had a similar but larger crack to the rear of our previous motorhome. It survived with some duct tape for nearly a year before we got the damage properly repaired very cheaply and to a very good standard in Morocco.
adt
adt
Mar 28, 2016
267
1,594
Cumbria
Nuevo
Since 2016
Thanks all.
The repair company is going to see if they can squeeze me in, but if not I think I'll try the extra strong tape ..... and a bit of steel bar, riveted, glued and then fibreglassed ! :whistle:;)
Lenny HB
52,694
147,624
On the coast in West Sussex
Hymer B678 DL
I'm in conversation with Bendalls (r-hind) but looks like they cannot get me in until the 13th and need it for 6 days.
The Hayling island one is a bit distant but there are boat repairers round Windermere I could try, thanks.
Make sure the boat repairer can match the Gel coat you don't want it sprayed. Any good boat repairer should be able to do, I was amazed at how good the repair was to the front of my Hymer that a local boat guy did.
Sep 23, 2013
2,579
8,604
Lincs
Globecar Campscout
If I remember rightly, @peterc10 had to wait awhile for a repair to be done to the front of his Hymer. It was a similar crack, but larger. I'm fairly sure he just used duct tape on his & I don't think the crack got any worse in the meantime.
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Thanks all.
If you want to do something useful you could contact the manufacturer of your van and ask then what is the RAL number for the Gelcoat, the repairer will want to know this.
Martin
Lenny HB
52,694
147,624
Hymer B678 DL
Martin
I don't know about other manufacturers but Hymer don't have have any codes for the Gel coat but any good repairer will be able to match it.
This was my damage, after the repair you could not see any sign of a repair even the glass behind the panel blended in perfectly.
Jul 5, 2013
11,713
13,681
Since 2013
Simon is correct. The duct tape lasted for 5,000 miles before I got the repair done. And it was holding the number plate on as well!
