Ignition doesn't recognise the keys b (1 Viewer)
pompeydelboy
10
Essex
Hymer B544
newbie
Help, we have a 1998 Hymer B544 and are having problems with the ignition. Key code is illuminating and it seems it doesn't recognise the keys. We have tried two different keys so it must be the reader not reading them ? Anyone help ?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
each key is slightly different and must be setup but I forget how to do it. Some one must have the answer. I suppose it could be a key battery problem not an easy one to sort out do you have the red master key or do they no longer exist.
43,207
48,802
If its on a Fiat chassis, at that age you should have a red key.....if you dont you're pretty much stuffed as you need that to program/reprogram keys.
Usual remedy is a new EMU (engine management unit) as the immobiliser is part of it.
approx cost ....£800.
pompeydelboy
pompeydelboy
10
Essex
Hymer B544
newbie
Problem sorted, have got a mechanic to override the diesel pump which was being stopped from working. Thanx for your replies everyoneeveryone
