Idiot question about twin wheels/axels (1 Viewer)
6pm Cowboy
916
South Oxfordshire
none ( yet )
0 - but I live in hope
This may make me feel like a complete prat but whats new ?
Many caravanettes :)Rofl1:) have twin back wheels, either on the same axel or twin axels, so...... how do you know when you get a puncture ?
The Wallace
367
5
I can answer that one!! It's not a daft question if you have never felt it.
The van 'sits down' on that side. Had one of the twin rear wheels rupture a valve stem on our first trip with the van to France. You certainly feel it.The remaining wheel can't take all of the load and If you don't stop soon it may blow out.
Have steel valves all round now - don't want to do it again!
bazfergy
558
4
dumfries scotland
a class
5 years
I had one on an old transit self build and when it blew it made a hell of a noise like someone was banging the floor to get in:Eeek:
Nov 6, 2008
3,943
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
Hi Graham,
Being an ex-HGV driver, l have had this happen to me, and you will notice on corners that something is amiss. Also there will be a large bulge in the remaining good tyre, because its now carrying twice as much weight. As for tag axles, it should become more apparent.
Craig.
scotjimland
2,261
9,793
A Woosh bang
You'll know when the second tyre blows out because of the extra load.. :roflmto:
Only had it happen on a twin axle caravan.. when one of them blew out the van gave a jolt but stayed under control.. but I have heard of RV drivers not knowing and ending up with two shredded rear tyres.. :cry:
You can get remote wireless sensors installed which constantly monitor the pressures and give an audible alarm if something is amiss..
Jim
6pm Cowboy
6pm Cowboy
916
South Oxfordshire
none ( yet )
a caravanette is too small to have a twin wheel let alone a twin axle.:ROFLMAO::ROFLMAO::ROFLMAO:
:Smile:
But raises an interesting point. I take it that in order of 'goodyness' a twin axel is better than twin wheels ?
The Wallace
367
5
Now you run the risk of this thread degenerating.
My preference is for twin rear wheels based on the fact that this gives 4 wheels driving.
Second or 'tag' axles are seldom driven which means you have a front wheel drive van. (nuff said)!
Other opinions are available and all PMs may be recorded for training purposes.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
twin wheel is far superior to twin axle as all four wheels are driven, giving a distinct advantage on soft or wet ground
6pm Cowboy
6pm Cowboy
916
South Oxfordshire
none ( yet )
I will bear that in mind but is the twin axel better for weight distribution or why ?
6pm Cowboy
6pm Cowboy
916
South Oxfordshire
none ( yet )
and a puncture would inevitably be on the inside wheel so I assume you have to remove the outer one first ?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
A twin axle may spread the load better but will also result in more tyre wear, however the twin wheel chassis is designed to take the max load anyway so what do you gain. Yes you have to remove the outer wheel to do anything to the inner one, on mine anyway, some may well have nipple extenders to overcome that. My main concern would be not getting stuck on rally fields, not having to carry large bread trays etc.
I would suspect that twin axle would use more fuel as well. try moving a twin axle trailer and compare to a single axle to see what I mean a huge amount of extra effort is required, plus you have the weight of the extra axle, more springs and bushes to maintain
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
I have a twin wheel single axle. The outside tyre punctured and shredded and then with the extra wheight on the inner wheel the inner tyre blew.
I new immediatley when the first puncture happend because you can stii see the brown stains on the M53.
Jim
:Smile:
moandick
1,312
112
Landrake, Cornwall
Euro-shed
:Smile:
Not according to many Caravan sites that have banned twin axle motorhomes/caravans due to the damage they cause on grass by 'turning' to tightly and screwing great lumps out of the surface of the grass.
43,305
49,296
as i have only one wheel on each corner it matters not to me which is 'superior'
but in my opinion twin wheel, single axle vans really do look 'commercial'.:RollEyes:
Tag axles look the part....:thumb: and unless you do a lot of 'junction' turns the tyre wear is minimal.
no more so than a twin wheel , when sharp cornering, where the outside tyre is taking a slightly larger radius than the inside on the same hub so needing to turn fast but cant due to it being bolted to the inner one.
one of the tyres has to take some extra scuff wear.
makes sense to me, does it to you?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Tag axles cost more on some bridges/toll roads in Europe as well.
43,305
49,296
as they do in the UK.
dont know about others cos i avoid 'em like pig flu but the humber bridge toll works on axle numbers.
twin wheel, single axle wrecker and a car on the spec frame = 3 axles on road.... goods vehicle rate. about £13 at the time.
return journey...just the two axles = heavy car rate :h:500kg...much cheaper. £2 odd
