Idiot question about twin wheels/axels
Discussion in 'Motorhome Chat' started by 6pm Cowboy, Aug 25, 2009.
  1. 6pm Cowboy
    6pm Cowboy Read Only Funster
    Jun 26, 2009
    954
    South Oxfordshire
    This may make me feel like a complete prat but whats new ?
    Many caravanettes :)Rofl1:) have twin back wheels, either on the same axel or twin axels, so...... how do you know when you get a puncture ?
  2. The Wallace
    The Wallace Read Only Funster
    Apr 3, 2009
    368
    I can answer that one!! It's not a daft question if you have never felt it.
    The van 'sits down' on that side. Had one of the twin rear wheels rupture a valve stem on our first trip with the van to France. You certainly feel it.The remaining wheel can't take all of the load and If you don't stop soon it may blow out.
    Have steel valves all round now - don't want to do it again!
  3. bazfergy
    bazfergy Read Only Funster
    Apr 20, 2009
    566
    3
    dumfries scotland
    I had one on an old transit self build and when it blew it made a hell of a noise like someone was banging the floor to get in:Eeek:
  4. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,074
    13,120
    Ramsey, Isle of Man.
    Hi Graham,
    Being an ex-HGV driver, l have had this happen to me, and you will notice on corners that something is amiss. Also there will be a large bulge in the remaining good tyre, because its now carrying twice as much weight. As for tag axles, it should become more apparent.
    Craig.
  5. 6pm Cowboy
    Jun 26, 2009
    954
    South Oxfordshire
    Sounds less dangerous than a normal puncture slewing you off line then.:Smile:
  6. scotjimland
    Jul 25, 2007
    28,934
    25,602
    You'll know when the second tyre blows out because of the extra load.. :Laughing:
    Only had it happen on a twin axle caravan.. when one of them blew out the van gave a jolt but stayed under control.. but I have heard of RV drivers not knowing and ending up with two shredded rear tyres.. :cry:
    You can get remote wireless sensors installed which constantly monitor the pressures and give an audible alarm if something is amiss..
    Jim
  7. 6pm Cowboy
    Jun 26, 2009
    954
    South Oxfordshire
    Sounds like a good idea.
  8. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    a caravanette is too small to have a twin wheel let alone a twin axle.:Rofl1::Rofl1::Rofl1:
  9. 6pm Cowboy
    Jun 26, 2009
    954
    South Oxfordshire
    :Smile:
    But raises an interesting point. I take it that in order of 'goodyness' a twin axel is better than twin wheels ?
  10. The Wallace
    Apr 3, 2009
    368
    Now you run the risk of this thread degenerating.
    My preference is for twin rear wheels based on the fact that this gives 4 wheels driving.
    Second or 'tag' axles are seldom driven which means you have a front wheel drive van. (nuff said)!
    Other opinions are available and all PMs may be recorded for training purposes.
  11. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    twin wheel is far superior to twin axle as all four wheels are driven, giving a distinct advantage on soft or wet ground
  12. 6pm Cowboy
    Jun 26, 2009
    954
    South Oxfordshire
    I will bear that in mind but is the twin axel better for weight distribution or why ?
  13. 6pm Cowboy
    Jun 26, 2009
    954
    South Oxfordshire
    and a puncture would inevitably be on the inside wheel so I assume you have to remove the outer one first ?
  14. Wildman
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    A twin axle may spread the load better but will also result in more tyre wear, however the twin wheel chassis is designed to take the max load anyway so what do you gain. Yes you have to remove the outer wheel to do anything to the inner one, on mine anyway, some may well have nipple extenders to overcome that. My main concern would be not getting stuck on rally fields, not having to carry large bread trays etc.
    I would suspect that twin axle would use more fuel as well. try moving a twin axle trailer and compare to a single axle to see what I mean a huge amount of extra effort is required, plus you have the weight of the extra axle, more springs and bushes to maintain
  15. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    I have a twin wheel single axle. The outside tyre punctured and shredded and then with the extra wheight on the inner wheel the inner tyre blew.
    I new immediatley when the first puncture happend because you can stii see the brown stains on the M53.
    Jim
    :Smile:
  16. 6pm Cowboy
    Jun 26, 2009
    954
    South Oxfordshire
    :Smile:Not sure what you are saying.
  17. johng
    johng Read Only Funster
    Aug 15, 2007
    588
    Kent/Sussex UK
    Jim, how long do you think it was from number 1 going and then number 2{s}
    :Smile:
    john
  18. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Hi John
    I reckon it was less than 10 seconds.
    Jim
    :Smile:
  19. moandick
    moandick Read Only Funster
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    Not according to many Caravan sites that have banned twin axle motorhomes/caravans due to the damage they cause on grass by 'turning' to tightly and screwing great lumps out of the surface of the grass.
  20. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    as i have only one wheel on each corner it matters not to me which is 'superior'
    but in my opinion twin wheel, single axle vans really do look 'commercial'.:RollEyes:
    Tag axles look the part....:thumb: and unless you do a lot of 'junction' turns the tyre wear is minimal.
    no more so than a twin wheel , when sharp cornering, where the outside tyre is taking a slightly larger radius than the inside on the same hub so needing to turn fast but cant due to it being bolted to the inner one.
    one of the tyres has to take some extra scuff wear.
    makes sense to me, does it to you?
