Identifying which battery...
Discussion in 'Tech/Mech General' started by oaktree11, Aug 27, 2015.
  1. oaktree11
    oaktree11 Funster
    Aug 15, 2015
    51
    26
    Cheddar, Somerset
    hi all,
    I have managed to think myself to a standstill! So, this might be a dumb one.
    The radio in my Ducato based Burstner is supposed to be powered from the leisure batteries.
    When I removed the old radio (certainly not the original) there is a whole mess of wires which have been discarded and a what I take to be a standard DIN plug spliced in.
    My question is, without disconnecting the starter or leisure batteries, how can I check which battery is feeding the live in the plug?
    John
  2. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,541
    2,548
    Trowbridge
    Continuity test from battery +ve to +ve connection on din plug
    But I would have thought disconnecting would be quicker and easier
  3. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    A sensitive volt meter? to check the slightly different voltages from the two batteries.
    Increase the voltage difference between the batteries, by connecting a charger to one of them.
  4. oaktree11
    oaktree11 Funster
    Aug 15, 2015
    51
    26
    Cheddar, Somerset
    Thanks guys. I agree that disconnecting one battery would be best. I will start with a continuity test. The starter battery is under the passenger footwell right below the radio.
    Appreciate the help
  5. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,027
    1,168
    Dronfield - Derbyshire
    I think you will find it is fed from the start battery, just fed by a permanent live, not through the ignition switch
  6. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,613
    11,288
    Taunton Somerset
    Pop the hazard lights on. One voltage will be stable one voltage will fluctuate
    Simples!
    • Like Like x 3
  7. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,460
    1,399
    West Midlands
    Now that's clever!
    Wyn
  8. oaktree11
    oaktree11 Funster
    Aug 15, 2015
    51
    26
    Cheddar, Somerset
    Normally I would agree but the Bustner book states several times that in Ducato based MH's the radio is fed from the Leisure batteries
    John
  9. oaktree11
    oaktree11 Funster
    Aug 15, 2015
    51
    26
    Cheddar, Somerset
    Now THAT is genius, thank you!
    In reality it doesnt really matter because when its off its OFF not on standby.
    John
  10. oaktree11
    oaktree11 Funster
    Aug 15, 2015
    51
    26
    Cheddar, Somerset
    And here is the finished article! I am quite pleased with it
    • Like Like x 4
  11. Drexxer
    Drexxer Funster
    Oct 26, 2014
    257
    281
    Lincolnshire
    Now that's looks a damn site neater than the crappy Blaupunkt with no reception that currently adorns my van! (y)
    Andy
  12. oaktree11
    oaktree11 Funster
    Aug 15, 2015
    51
    26
    Cheddar, Somerset
    Andy, I am available on a free consultancy basis!
    • Like Like x 1
  13. eddievanbitz
    Oct 4, 2007
    3,613
    11,288
    Taunton Somerset
    That means you'll loose all of you "saved" settings and radio favourites.
    The"standby" which is normally ignition controlled is best disconnected and a constant 12 volt supply connected to the standby with a small switch in series
  14. oaktree11
    oaktree11 Funster
    Aug 15, 2015
    51
    26
    Cheddar, Somerset
    By the way, the trick with the flashers works like a charm! Thanks again
    • Like Like x 1
