JockandRita
- Aug 2, 2007
- 11,447
- 149,906
- N+B Flair 8000i
- Since May 05 (Ex Tuggers).
Can someone help please?
Having scoured the internet, I can find similar, but not the same 28/30 Mbar LPG regulator pictured above, which forms part of our bulk gas installation, and came with the MH. It is in good working order, but is time expired (if the two digit number underneath is anything to go by ).
Underneath that silver paint, there are traces of red, which also confirms it is a propane regulator, much like some American camping applications. To save any modifications, I would like to change it "like for like".
The threaded female inlet and outlet, appear to be 1/2 inch (12mm), with double male adapters at either end.
A local reputable dealership accessory shop advised that the Comap Clesse regulator (pictured below) was a direct swap.
As you can see, it clearly isn't a straight replacement or a direct swap.
Any help with the above, would be gratefully appreciated please.
Thanks,
Jock.
Thanks,
Jock.
