iBoost & effect on other users (1 Viewer)
Eamless
192
949
London
C class
Newbie
Getting too technical now guys....dummies terms please.
I will try.
Will a boost system take up more bandwidth than a non-boost connection? No
Will a boost system provide faster download speeds? Maybe
If you are at a distance where you are experiencing data loss then you may see better throughput through a boost. However the tablet, PC, phone you are using to connect with will also have a huge say with the speed of your on-line experience. Additionally you sometimes find the longer you are connected the slower your connection will become. This is how some networks in the UK are set up, let the punters think this is really fast when they connect and them send them down the pecking order when new connections arrive.
Can Campsites, WiFi hotspots,etc see if you are using a boost and block you? Yes
A lot of WiFi providers use Ubiquiti Networks to provide the service. iBoost is a Ubiquiti Nanostation Loco M2 with a sticker on it. This will show up on their management software as a Ubiquiti client. Currently this is a rare event, we have been blocked twice in Spain and once in Greece.
What is 5G and 2.4G?
This is the bandwidth the signal is being broadcast over. Normally 5G is used within buildings but we have seen two campsites using it. The reason is to sell you a system and stop you using boost systems. I doubt this idea will catch on.
Shall i buy a boost system? Depends.
If you primarily stay on campsites then probably yes. But i wouldn't spend much money on one. The reasons are you will be mostly connecting to slow, non-secure networks. You should never use one to transfer any private data over. Cellular is the way forward if you tend to move around and not stay on campsites. Mobile phone service is far superior once you leave the UK. We normally now connect to 4G and only in remote places does that drop to 3G. You will get a shed load of fast, secure data for the money you pay for a boost system. Also if you have to keep buying coffee to get passwords then you must factor that into your costs.
A Huawei E5372 MiFi does both. It is a router that connects to 4G and Wifi and so covers both bases. You can also add an external aerial to it to extend the range. it is not as good as a boost on Wifi but it is not bad. On Cellular it connects at up to 150mb, that is 50x faster than most campsite WiFi.
If you plan to buy a boost then look for a Ubiquiti nanostation Loco M2. Should not be more than about £40. This is used by every RV owner in the US, every leisure sailor around the world. If you do this set the country to United States and it will have twice the power of other boost systems. it might make your hair fall out and fry children from a 100 yards but it will allow to connect to systems a lot further away. You could also try a bear extender, especially if you are a Mac user.
Hope this helps
Eamless
192
949
London
C class
Newbie
Please can you explain why?
Because In the EU we have power limits. Basically to stop 'leakage'. The US does not impose these limits on their equipment.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
This will increase the potential transmit range of your iBoost, but it won't do anything to increase the range of the station that you are connected too. The transmitter that you are connected to will (probably) be set to the EU standards. An internet connection is a two way thing - increasing your transmit power just ensures that the limiting factor is the strength of the signal coming from the other station, rather than your signal back to them.
If you are the sort that worries about electromagnetic radiation, then if you do turn the power up, make sure the antenna is up on the roof & don't stand in front of it! :D
I don't really know, but I suspect the regulations are more to do with interference than likely dangers. Shame really - there are days when fried children can sound like a positive benefit. (y)
Eamless
192
949
London
C class
Newbie
But it does allow to see stations further away. Yea it is to do with leakage. I have seen a system installed at a well known airport to the west of London that colmpletely took out the Bluetooth system used for tracking passengers.
Apr 9, 2014
1,307
6,596
Lincs
@Eamless, enjoyed your post and intrigued by the line below:
I have two boxes one is a Mifi unit (netgear aircard) with external aerial that connects to 3/4G and creates Wifi hotspot in the van, the other is an Wifi Router (Alfa R36) with an external aerial that connects to a local Wifi point and creates Wifi hotspot in the van. So 2 boxes one for Mobile and one for Wifi, it would be great to just have one box and therefore one admin interface. Is this what you meant/have?
Addie
Trader - Motorhome Wifi
Oct 15, 2011
553
834
York
The Huawei E5372 or E5577 as it is now has a 'WiFi repeater' functionality. It's not technically a booster, since neither of the two external antenna tracks are associated with the WiFi part of the card but are instead used for a MIMO 4G antenna for the cellular side. Incidentally the 'WLAN mode' being turned on for older models will disable the 3/4G connection - the newer devices (E5577 onwards) won't do this so if your device stops working after playing with this function watch out for this.
You'll likely have 5 bars because you'll be sat right on top of the device, but the unit itself probably won't afford a much better connection to the WiFi source then your laptop will. It's useful for bridging a gap or if you have a device eg a tablet with very poor WiFi performance (eg, WiFi is great outside the van, but poor inside - put it outside in a Tupperware box or right in a window) and allowing a multiple users off a single login if the signal is strong but your Alfa R36 and presumably external USB WiFi antenna will probably do a better job, especially as this is two radios (one local, one remote) rather than one (Huawei - one radio, both broadcasting locally and connecting remotely). Sometimes this is 'just enough' but as Eamless says it's not as a good as a booster like that one you have already.
Adam
Lenny HB
53,421
149,947
On the coast in West Sussex
Hymer B678 DL
You have got one that will do both, you can plug a 3G dongle straight into the R36, obviously no external aerial but a long USB cable and put the dongle on or above the roof improves the signal.
Apr 9, 2014
1,307
6,596
Lincs
Yup, one reason we bought in the first place but after trying the R36 and a Mobile USB dongle, it did work but not simple, had problems with firmware and dongle compatibility. The netgear is really easy to use, battery lasts for ages, 2 aerial ports good reception, excellent little device. The R36 with USB Wifi and a good Aerial is also terrific.
But, been 2 years now, so ideally I would like to replace the R36 with something with a better admin interface, but still allows the attachment of a external aerials and maybe 3/4G.
Addie
Oct 15, 2011
553
834
York
If you have the Netgear Aircard 762s onwards then you can download a free app for Apple/Android which makes the admin interface a bit easier to use as its not particularly intuitive.
Huawei really have cornered the market in device usability if you get a factory unlocked model rather than previously network locked. Their stock interface and Huawei HiLink smartphone app really is great for understanding what the device is doing and making any configuration changes.
The E5372 or its replacement the E5577 both have TS9 antenna connections like your Netgear, I would avoid the E5377 as it has CRC9 antenna connections which are a bit more fragile.
Apr 9, 2014
1,307
6,596
Lincs
Yes I like the Huawei kit and the Netgear app is ok, though the netgear is so easy to use once setup no admin is needed, just put the SIM in and switch on. The Alfa R36 is the hassle dated interface, bit slow and tricky to use on a phone, all works fine and therefore no rush. Will have to swing by your stall @Addie one day to see what the new stuff all looks like. :)
Eamless
192
949
London
C class
Newbie
Adam
I disagree. I have been using this for two years thoughout Europe
Unfortunately I run two boxes, Ubiquiti for WiFi and the Huawei for cellular. However, I sometimes put the Huawei in a tupperware box and tin foil behind it and it works in most cases on the rare occasion I might go to a campsite.
I prefer to be on a cellular connection at all times but some countries like Portugal make it rather expensive so I might drop to a boost system.
So the boost system is now becoming more and more of a back-up item. That is the reason not to spend a great deal of money on one. Spend your money on the data.
Many years ago when I started in IT I worked out hardware was a commodity. So I concentrated on the software. I then worked out that was a commodity and concentrated on what people want. And what people want is cheap, fast, secure internet connection. Whatever its current failing Cellular is the only solution that will ever provide that.
reckless
Sep 11, 2014
1,012
3,482
West Sussex
None
Since 2013
I keep thinking, yep I get it, then someone adds another comment and I'm flummoxed again :(
Here's what we've got - I have a Sony phone with a 3 contract SIM, I also have a Lenovo tablet. Brian has a Samsung phone and a laptop. We also have a Huawei E5372 with a 3 contract SIM. No boost, no external aerial, no iphones or iPads.
We stay on a mixture of Aires/sites. We're currently in Spain and my phone can't be used as a hotspot.
We're struggling to get a decent signal with either 3/4G or WiFi provided by campsite (free or charged). Whichever device we try we're lucky if we can comfortably browse a few web pages. Invariably we give up.
So what extra kit might help us to achieve a reasonably reliable connection? This may have been covered above but I can't pick out the bones! Thanks.
Karen
Eamless
192
949
London
C class
Newbie
You have 4 choices:
1. Get an external LTE MIMO aerial for the huawei. £30. This will greatly improve reception.
2. Get a replacement sim for the huawei with someone with better coverage in Spain. Only possible if huawei unlocked. £?
3. Go to cafes and bars. £?
4. Buy an extender. You can go from £40 for an Alfa or nanostation loco m2 up to a lot of money for a nanostation with a sticker on. This solution will only allow you to access these slow hotspots from a greater distance.
Personally if you have a cellular contract go for option 1.
If you mostly use campsites go for option 4 and buy a ubiquiti nanostation loco M2 or something similarly priced.
reckless
Sep 11, 2014
1,012
3,482
West Sussex
None
Since 2013
Thanks @Eamless I get it. I really do!
Options 2 and 3 aren't feasible so we'll go for 1 and see how we get on.
Thanks again for your clear replies.
Karen
Eamless
192
949
London
C class
Newbie
Karen
If anyone has or is considering getting a MiFi then make sure it supports an external LTE MIMO aerial otherwise you are just wasting your money unless you are always less than 500m away from an antennae.
DBK
18,022
48,093
Plympton, Devon
PVC, Murvi Morocco
Karen
As @Eamless says, an external aerial can make a big difference. I've just got the 5377 MiFi, a few years old now and with the fragile antenna connector but even a cheapo £10 antenna can make the difference between a signal and no signal or 3g instead of 2g.
Having a different sim helps too. I use Three in the MiFi as the default but if it can't get a signal then I take the sim out of my O2 phone and try that. It does incur a charge of £1.99 per day I use it overseas but if I need to connect then this isn't extortionate for a few days a month.
Unfortunately, I also had a Vodaphone Europa sim as a third option but got caught out by the not topping up for a year rule and now it's died!
reckless
Sep 11, 2014
1,012
3,482
West Sussex
None
Since 2013
Brian doesn't think our E5372 has a port for an external aerial.......doh! Just bought it as a solution for Europe, or so we thought.
Karen
DBK
18,022
48,093
Plympton, Devon
PVC, Murvi Morocco
Karen
It should have two connectors, little round things. If it doesn't you've got a duff one! And Europe is where you need the external antenna especially if you are stopping outside built up areas, such as sites or aires by the coast.
Bandybash
Oxfordshire
Bailey
Since 2014
Best solution I have found to be the MIFI, get an unlocked prepaid one do you can use local data SIM cards abroad. Contract EE & 3 are no good as you have to keep buying data addons to get better speed whilst roaming, and their websites and customer services are pants. I use EE in UK but never top up I just buy a new sim, it's easier. I will use an EE card short term say when transiting France for Spain, then you can just text to buy data so I make sure there is some credit on it before I leave UK, then buy a local sim on arrival at destination country. That bandwidth problems are a thing of the past?
reckless
Sep 11, 2014
1,012
3,482
West Sussex
None
Since 2013
It should have two connectors, little round things. If it doesn't you've got a duff one.
We've just had a mini domestic and after swearing black is blue, he's found them LOL
So next step is buy an antenna
Karen
DBK
18,022
48,093
Plympton, Devon
PVC, Murvi Morocco
Karen
You want a 4g MIMO one, it will have two cables. Something like this but there is a wide choice, including ones you mount permanently on the roof.
Broken Link Removed
reckless
Sep 11, 2014
1,012
3,482
West Sussex
None
Since 2013
As a PS to this thread, we started putting our Huawei mifi on top of the blind under our skylight (inside the van) and getting much better signal.
We wouldn't have thought of that if not for reading some of these comments so.......thanks.
Karen
