I think I have alternator trouble
Discussion in 'American RV's' started by MistyMurphy, May 10, 2009.
  1. MistyMurphy
    MistyMurphy Deleted User
    I am new here bet you carnt tell, been full time 2004 till 2008
    I have recently changed job and it means i have to reside in a cold old house.
    we so miss the friendly faces you wake up to every morning surrounding you on fields around the country. The morning sun gushing thro, the windscreen as you open the blinds, and just the simple freshness as you open the awning and flop in that big lounger with the little pooch just 1/2 a step behind scrambling to get in the chair before you do.
    The help we have had over the past few years has been tremendous since changing over to our RV the help has not been any less. we try to get away most weekends but at the moment I think I have an alternator problem, we returned from easter break in Cromer, drove about 70miles back home and turned off engine went into house came back 10mins later to take Rv to storage and the damn thing would not start. Had to jump start with my good old smart car. It did the same when i got to storage and had to jump start again.....
    Has anybody got any advise.. its a ford engine 7.4 +lpg conversion I cannot get at alternator myself to remove so looks like trying to find local Ford truck place to have a go.Its a newish battery maybe 6months old thats all and it charges fully with battery charger but will not start engine.....help please if possible
    [​IMG] [​IMG]
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    East Sussex 01-580-881288
    Hi,
    Does the alternator charging light go out when the engine is running.
    Peter
  3. MistyMurphy
    Hi Peter, yes it does, I do not have any warning lights on at all, everything is normal
    thanks
    Alan
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    Hi alan,
    Sounds like the alternator is OK, check the fuses, hopefully Geo of the greasy spanner will come along later
    Peter
  5. Thepips
    Thepips Trade Member
    Sep 26, 2007
    500
    Basingstoke
    That makes me think it's the battery more than the alternator but I've been wrong before!
    Have you checked the battery levels? I'm lucky on my RV as I've two chassis batteries. I had a very similar problem but disconnecting one battery and the engine started immediately.
    Hope that helps
    Regards
    Doug
  6. MistyMurphy
    thanks so far i will look into those when i go down to storage later
    ta, Alan:thumb:
  7. 45eEver
    45eEver Read Only Funster
    Apr 15, 2009
    267
    Murph, have I understood correctly, you can't start with your MH battery fully charged by your charger.
    But you can start when your car battery is hooked up to your MH battery with jump leads.
    If I've underswtood correctly, it sounds like your MH starter battery is duff.
  8. Bigtrev8xl
    Bigtrev8xl Read Only Funster
    Mar 31, 2009
    20
    Ipswich
    Hi.
    Have you checked that the terminals on the battery are clean, it could explain why you are able to start it ok when you use jump leads, I’m assuming you connected the jump leads to the clamp and directly to the battery terminal.
    Cheers Big Trev.
  9. MistyMurphy
    BIG BIG thanks to you all
    Thanks for the last two comments, went back to it today and found a burnt out 30amp fuse that was tucked out of sight. Thanks to Peter, for suggesting about a fuse, I really had to look hard to find it took me nearly 45 mins repaired and replaced fuse holder and some connectors, It started with the jump leads again because battery was low, after about 45mins i switched off, left for about 30mins and it then did start again so hopefully a very good result, i wil see again tommorrow when i go back and start it again....BIG thanks to Peter looks like a pint I O U if we ever meet...
    Alan:thumb::thumb:
  10. 45eEver
    Apr 15, 2009
    267
    Where was the fuse please Murph?
