I need water pump, Italy
Discussion in 'Motorhome Accessories' started by Billy23, Aug 17, 2016.
  1. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    On a planet...far, ....far away.
    My water pump is gradually fading so I need to get a new one. Trouble is I am in Italy, Verona today, then on to Venice, Bologna, Florence, Pisa, and gradually down to Rome.
    Question is, has anyone a suggestion for buying a replacement in any of those p!aces?
    Thanks for any help. :)(y)
  2. SUGGY
    SUGGY Funster Life Member
    Nov 23, 2011
    928
    1,661
    scunthorpe
    You haven't given much information about the problem but :-
    is it a shurflo type , ?
    it could be the filter on the end that is blocked , or crap build up behind the diaphragm.
    They are easy to take apart and clean , just take your time and lay the bits out as you take them off or draw the layout ,
    when you take the feed pipe off push a screwdriver or the shaft of a pastry brush up the pipe to stop it emptying your water tank ...
    when you have cleaned everything smear all the surfaces with Vaseline to reseal the "o" rings surfaces ,
    i have repaired 2 this way ,
    Good luck .
    • Like Like x 3
    • Informative Informative x 1
  3. worky
    worky Funster
    Mar 6, 2008
    52
    25
    worcester
    hya Billy - we've used West Caravan centre about 1km east of Peschiera del Garda, it has a large accessory/spares shop and I would imagine you'll be able to get a spare there. Co-ords are N45.434054, E10.708978, hope that helps
    cheers
    Clyde
    • Like Like x 4
  4. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    5,952
    11,338
    East Sussex
    In Pisa the Aire is owned by the Pisa Motorhome Owners Club.
    They should be able to direct you to a local supplier if you need one.
    Motorhomes are very popular in Italy so you should have no problems finding a local dealer.
    • Like Like x 2
  5. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,852
    8,154
    Lincs/Cambs border
    Same recommendations for West Caravan Centre here too, if in that area.
    I'm with @SUGGY though, ie, fault-finding, as often it can be something simple, such as a fuse blown, loose connection, clogged filter, or a seized impeller. I had to free one up with a tiny screwdriver once.
    If it's a Reich pump with the twin impeller, often the little plastic shaft breaks away. It's a new pump then. :(
    Good luck with it Billy. (y)
    Cheers,
    Jock. :)
    • Like Like x 1
  6. pjay
    pjay Funster
    Feb 3, 2013
    137
    134
    Norfolk
    • Like Like x 1
  7. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Thanks for all the great advice. I will first of all do as @SUGGY suggested as, when I think about it, the flow is reduced so it may well just need a clean.
    Just coming into Verona for 2 nights so will do it today. (y)
    • Like Like x 1
  8. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    OK, the follow up.
    Took the pump out, cleaned filter, put it back..........Nuffin, pump started up but no water. Surprised really as I really didn't take it to "Bits" and it pumped a little water before . :)
    So looked on the wall of the aire in Verona and a poster told me of a camper shop, just about 4 km from the aire, off I went second thing this morning. Lucky for me, although it was some sort of holiday (August shut down I think) they had one man on duty, have you got a pump young man, YEP we have!! great result. Same pump "Fiamma Aqua 8".
    Short story long, connected it, Bingo!!! Will take the old one home and play with it, if I get it going......I will keep it as a spare, as many will know, it is not funny when the pump gives out and the weather is HOT!!
    Just to put it on record the name of the Caravan dealer is:
    Wingamm
    La Vie on Road
    Via Nassar 40
    Settimo Pescantina
    Verona, Italy
    Co-ords 45 28 56 N 10 54 50 E
    And Google maps: 45.482012, 10.913696
    Thanks for all the good suggestions from you guys. I smell quite nice NOW :D(y)
    • Like Like x 4
    • Funny Funny x 1
