I need some advice with electrics? (1 Viewer)
Scarabs
5
Manchester
Van Conversion
2 years
Hi there, I am new to motorhoming and I have the bug already. I am constantly trying to improve my van. However when it comes to electrics I have come a little unstuck. I have a convertor that I have installed off my 120ah 12v leisure battery and I also have a mains hook up in place. Does anyone know if there is a way that I can wire it up or add a component to allow it to automatically use the mains hook up when it is available thus saving my leisure battery? All help and advice would be much appreciated.
big map
4,597
182,269
Poole
Since 2009
Hi and welcome. I haven't got a clue but someone who has will be along soon.
Jan 10, 2013
5,958
7,354
Near Uttoxeter and Crete
Warwick XL PVC
Still trucking and learning
Me neither, but
S
Scarabs
5
Manchester
Van Conversion
2 years
I want it automatic gillnPhil so that I can store the invertor out of site plus I thought it would be a good feature to the electrics. It's just how to do it? I've heard of change over relays and coils but I don't know how they work or how to wire them up.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
What is the inverter used for and what rating is it. They are not a good idea on such a small battery.
Most low power items are usually fed via a transformer and often can be powered by a 12 volt adapter
andy63
4,672
15,017
south shields
None
since 1990
Hi and welcome...don't have an inverter but what you propose can be done.. I'm sure some on here will have such a system..
There is plenty on line as well if you Google it..
I'll try a link but don't always work with phone.
http://www.motts.org/INVERTER.htm
Andy
S
Scarabs
5
Manchester
Van Conversion
2 years
The invertor is more of a back up should I need it in an emergency if mains hook up isn't an option. It's 2kw output if I remember.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Clives is OK but the contactor hum will get on your tits eventually.
There is a feature in the resources section but I believe you need to be a paid member to access this
Techno
Jul 28, 2010
15,475
20,756
May 2010
A 2kw invertor will if used anywhere near its capacity will kill your battery very quickly
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
We have an 1800w inverter fitted and wired into the mains circuit and that has a automatic cut out when the mains is plugged in, so it can be done.
Just don't ask me how it's connected as it was fitted by those magicians at VanBitz so I don't have a clue.
Richard.
PS Welcome to Fun. :)
Apr 27, 2016
6,858
7,965
Manchester
A class Hymer
Since the 80s
When you first start down this path, it's likely you don't appreciate how much energy mains appliances use, and how little energy is stored in a battery.
2000 watts requires 2000/240 = 8.3 amps at mains voltage (240 Volts)
2000 watts requires 2000/12 = 167 amps at battery voltage (12 Volts).
That is a LOT of amps to draw from a battery. In theory a 120 amp-hour battery will last 120/167 = 0.72 hours = 43 minutes before it is completely flat. In practice you'd be lucky to keep it going for more than 20 minutes.
Most of the high-wattage appliances involve heating, so most people use gas versions (oven, hob, kettle, water heater, fridge, room heating).
Having said that, if you just want to run an 800 watt microwave for 10 minutes, you'll probably get away with it.
That's on my list of future mods, to replace the manual switch.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Interesting as I went the other way
All 13 of my sockets are available on mains or inverter but for me I'm either off hook up for many days or not and as I have to go in the garage anyway I flick the switch over at the same time as either getting out the hook up cable or switching on the inverter
Jan 8, 2013
8,490
11,526
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I have two sets of sockets.
2 sockets are specifically wired to the inverter (TV & sound bar) I left the existing sockets (fed from the hook up).
I am almost always wild camping so seldom need to change over.
When I am on hook up I simply change the plugs over to the original sockets.
Techno
Jul 28, 2010
15,475
20,756
May 2010
This is the latter day version of the resources article
Perhaps it will tempt @Scarabs to cough up :LOL: meanwhile he might double his battery capacity
Jan 28, 2008
10,113
18,366
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if its only for emergencies one socket that runs from the invertor has got to be the simplest system and only switch the invertor on when needed
Terry
11,929
9,044
Lincolnshire
Can't remember ;)
Hi I have a Victron pure sin wave inverter come charger that does exactly what you require (y)Not cheap but works all sockets on mains then inverter once unplugged ;)
terry
