I need a good laugh re covers (1 Viewer)
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi Kiddiwinks
I started a different thread ref cleaning my Motorhome earlier now I've decided what I'm going to do with that problem,
I would now like to know what you good people think about covers over the winter, do you use them, do you recommend them if so which one or are you of the opinion that they are a waste of time.
All comments welcomed especially funny ones, I could do with a good laugh now I've found out how much to have my Motorhome valeted. :-/
Many thanks Tony
Hymie
810
1,005
Essex
Classic Hymer B564
Since 1981
Winter cover?
We still use her at least every other weekend throughout the winter so no need for a cover Tony.
Hope to be spending most of the winter in Spain and Portugal this year.
Hymie.
DuxDeluxe
14,658
72,763
Planet Zog
A woosh bang van
since 2008
Hi Kiddiwinks
Many thanks Tony
If they don't fit perfectly and completely snugged down they can rub the surface and damage it, plus even breathable covers can trap moisture. I bought one for first van and never used it more than once after discovering the hard way how much of a pain they are to put on and off
D
Deleted member 29692
Never even considered one because we use our MH all year round.
FJmike
972
1,046
Swindon
over ten years
Before putting any cover on the van must be spotlessly clean as any dirt left on will be ground into the van surface. As has been said even the "breathable" covers will trap moisture in the van resulting in green mould over surfaces inside the van. Unless the van is in a very sheltered position the cover will move and damage the van surface, I have seen vans with the gel coat rubbed through on the corners.
Oct 15, 2011
4,161
11,260
Not Glasgow
Carthago chic eline
Since 2011
Will also block your solar panels.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Never had one, always thought that any movement would abrade the surface, more especially if not thoroughly clean. and if they rub against Acrylic Windows?. I always think that the one`s you see on the fronts of Caravans, will eventually produce microscopic scratching as no matter how tight you get the straps they are going to move?
I do have one though for the Triumph, "auto pyjama`s" (currently undergoing "surgery"!). And used as a "Dust Cover", as it lives in the garage in winter, where it`s nice and warm (ish).!!.
Pete
funflair
19,339
30,205
Guisborough
MORELO palace
since 2012
Ours is covered with a big shed and seems OK, no problems with it rubbing or breathing as it a fairly loose fit BUT the roof part does cover the solar panels which means I run the EFOY fuel cell in storage.
Martin
TerryL
6,180
8,180
North East
Low Profile
Have never considered covers for any vehicle I've had. My belief is that they were made to live/operate outdoors so should be okay without them. However any vehicle benefits from being cleaned regularly and, more importantly, being used, even if only for half an hour every couple of weeks.
Jun 16, 2013
1,228
820
Wiltshire
Low Profile Hymer CL 554
Since May 2014
When we had a caravan we covered it in winter. Such a faff to put on and take off. Kept the van clean but it caused lots of condensation inside. Would not have one for MH we use it too much.
Lenny HB
53,417
149,914
On the coast in West Sussex
Hymer B678 DL
It would be a pain in the arse to put on and discourage you from using the van and even if you are not using the van you should be taking it out for a drive every few weeks. You get far more clutch, engine & brake problems with vans that are left standing.
appydaze
728
1,845
southend on sea essex
Merc high top
20 years
Its like a loose condom............... not that I'd know, you understand.... :whistle:
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
You've been looking over the urinal haven’t you, I must watch who is standing next to me when using public toilets next time :)
Best Wishes Tony
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Never used a cover, seems they produce more problems than they cure.
Hi Reallyretired Yes it seems that this is the concensus that these covers can be more problems than enough, but I was hopeing to reduce the cleaning to the roof not the rest of the van which I can access quite easily.
Best Wishes Tony
