I fancy one of these
Discussion in 'Web Connections' started by Jim, Apr 21, 2010.
  1. Jim
    Jim Ringleader
    Jul 19, 2007
    26,122
    77,174
    Sutton on Sea
    [​IMG]
    These amplifiers claim to be able to bring in wifi signals from miles away (literally). I love using other peoples bandwidth so am considering this one.
    I know I could use a colander or fish frying basket but the repeatit looks a lot neater:Smile: Some forumgoers on a yank site say they can go from finding just 2 hotspots on a laptop and when they connect the repeatit, get upwards of 30 hotspots, many of which are free or unsecured! Sounds good, Has anyone used one.
  2. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,824
    36,074
    Leicestershire
    Looks good, I am very tempted.
    ShiftZZ
  3. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    939
    cheshire
    speak with jj Jim he has used one that a friend has and was on about getting his own, the company that produces them is in England. check the link below
    http://www.faculty-x.net/su2410-usb.htm
  4. activecampers
    activecampers Read Only Funster
    Jul 28, 2008
    420
    102
    Heathrow
  5. lebesset
    lebesset Read Only Funster
    May 31, 2009
    760
    no climbing on my roof please
    I haven't had 5Km's , but a big improvement on my chinese chip strainer
    word of warning though , these work on usb2 , and I have a problem because my ports are giving trouble , probably a fault on the computer , but could be because the power drain is on the high side and it cuts out because of overload , then get message plug into usb2
    suffice it to say that I tried a friends dell , and it worked perfectly , but I didn't run it for too long in case it damaged his ports as well
    my laptop [ a new acer ] will go back for repair [ still works as usb1 and 1.1 ] and will see what happens
    my take is that the 500mA of usb 1/1.1/2.0 is marginal for this device ; in the final analysis I could plug a usb3 adaptor into the express card socket as this is rated at 900mA ...but that is yet another £50 or so , and why should I have to do this ?
    incidentally , designed and manufactured in sweden , taiwan components undoubtedly
  6. activecampers
    Jul 28, 2008
    420
    102
    Heathrow
    How do you rotate that if its fixed on your roof?
    I think you are right over the power requirements as they get fairly warm (well mine does) do it is likely maxing the power output. It is possible to get a dual USB cable thingie (which I have on some external HDD drives) where it pulls USB power from 2x ports though has data connected only to 1x.
    USB 1x should also be 500mA though - so guess your laptop can be iffy. I have seen other makes (Dell) with USB ports that fail to provide maximum power.
    edit: See http://www.aimtec.co.uk/addonics-online/dual-usb-inputs-power-cable.html - usual disclaimer that it may or may not work depending on your equipment blah blah
  7. Robinhood
    Robinhood Read Only Funster
    Mar 7, 2010
    159
    Sherwood Forest
    You could always try a USB cable with a supplementary power lead (if you have more than one USB socket). In theory delivers up to double the mA. Not guaranteed to work, but I have one of these for use with a USB powered external hard drive, and the DVD drive I got for use with the netbook came with one as standard - though on this you only need to use it if it won't power on a single connection.
    Something like:
    http://www.lindy.co.uk/usb-firewire...mpaign=lindy&gclid=CJ_R7pynl6ECFcOX2AodOzXjOA
    (Other suppliers exist)
    HTH
  8. lebesset
    May 31, 2009
    760
    it's fitted on the mast for the digital terrestrial aerial which sits on top as you can see ; this mast both lifts and rotates
    I have had a double feed for some years , but would have to find some way of connecting 2 males together of course , probably exists but never seen one ; the alternative is the one in the link which is an extension with the female entry , but again , why should I have to do this ?
    point is , careful thought is needed before investing in this excellent bit of kit !
  9. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,452
    2,548
    UK / Spain
    Hi Jim, we have one of these:
    http://www.hawkingtech.com/products/productlist.php?CatID=32&FamID=60&ProdID=398
    What ever you spend on them they soon pay for themselves one way or another,:Wink: we have been on a few sites in europe that only have wi fi on certain parts of the site with an Antenna you can park anywhere. :BigGrin: With our one it takes a bit more effort walking around the van finding the right window.:Rofl1::Rofl1::Rofl1: Bob.
  10. lebesset
    May 31, 2009
    760
    someone lent me one of those to try when I was looking to buy something
    unfortunately it wasn't nearly as good as my chinese chip strainer/wifi dongle combination , so I returned it with thanks ; I think the main problem was that you can't mount it high up , and you had to use the laptop convenient to it
  11. scotjimland
    Jul 25, 2007
    28,934
    25,589
    We also have one of these.. found it great at the Lodge CL,
    We were about 200mt from the wireless router that was inside the owners house, we were also behind tress and a brick outhouse.. without it there was no signal, with it we got full 5/5 signal .
  12. bobandjanie
    Apr 28, 2008
    4,452
    2,548
    UK / Spain
    Hi, maybe you had it facing out the wrong window.....:Wink::BigGrin:
    We have not had a problem with ours, and very happy with it.:thumb: Had it about 2 years.
    But then I haven't tried a chinese chip strainer.:RollEyes: :Smile: Bob.
  13. Rainbowchaser
    Rainbowchaser Read Only Funster
    Feb 27, 2010
    332
    5
    Third rock from the sun
    thingamyjig
    Had one for a few years now. Excellent bit of kit.
    I can pick up secured/unsecured at least 3 miles away.
    I either take the bracket off and stand it on the roof or clamp it to a pole and tie it to the door mirror mount so you can rotate it. Works on the MH pc and the lappie no problem.
    :Smile:
  14. Jim
    Jim Ringleader
    Jul 19, 2007
    26,122
    77,174
    Sutton on Sea
    Is that the hawking or the repeatit ?
  15. Rainbowchaser
    Feb 27, 2010
    332
    5
    thingy
    Hi Jim,
    It's the 'Repeatit'
    They sometimes pop up on e-bay.
    T
  16. Jim
    Jim Ringleader
    Jul 19, 2007
    26,122
    77,174
    Sutton on Sea
    Thanks I'm definitely up for one:thumb:
  17. johngee
    johngee Read Only Funster
    Aug 19, 2009
    59
    Hampshire, UK
    I have one and it rocks.
    Here in the land of suburban bungalows I can find 5 sources without, and 11 with, and that's just by placing it on the window sill. It's quite directional (70-80 degrees), but it's worth a bit of fiddling, like the directional TV aerials as opposed to the omin-directional ones.
    Across open water I once connected to a source about 6 miles away.
