I Boost question (1 Viewer)
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Not having my instructions with me and for once being spoilt for choice, given the various numbers on the screen shot which would you expect to give the best signal
spitfire
2,408
5,135
Correze France
Bavaria
Since 2003
From the instructions :)
The closer to 0 the first figure listed in the signal/noise column the stronger the signal is ; so -46 is stronger than -80 .
Ideally attempt a connection to signal of -80 or better
andy63
4,672
15,017
south shields
None
since 1990
The camping albufeira 38/99 should be your best bet...
You don't want to connect to your I boost which will show the best signal...
The lower the first number the better..
And of course you need the pw for the chosen network..
Andy
May 8, 2011
3,854
48,381
God's county. Helmsley, North Yorkshire.
IH Tio 630 RL
Since April 1846 but have always camped.
well. the first 10 aren't a million miles from each other so I'd start at the top and work down. (my view only)
Doh! if only I'd gone and got the instructions before I'm replying. This is why I can never connect! :(
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Lower Is best(y)(y). Just does not FEEL correct but it is!:D2. Next doors "i-Boost" looks best!:D2.
Never did quite understand it, But?:rolleyes:
Welsh girl
3,658
3,036
Globecar
Since 2004
I'd go for the camping Albufeira 38 signal, that's the lowest I've been told to aim for the lowest figure. The other I boost close to you would need their password to connect to but if your friendly enough you could ask them and put your own iboost away. .. only joking. . Use the 38 signal!
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
After reading this I'd go for the highest number
It will be less crowded and faster :doh:
Clive
1,296
1,782
Canvey Island
If you click on the signal column it will sort highest to lowest, click again and its lowest to highest. Saves looking down the list(y)
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Password is Manchester untied:rofl:
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Agree with everything before Alan but remember to press the "Lock to AP" button not the select button. You have so many with the same name you will never know which one it is certain to connect to.
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
There is some ambiguity here. Is the lowest number the bigger one, because it's negative?
I think you need the biggest difference between the two numbers (signal and noise).
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Click on signal/noise header and it will sort column in signal strength, clicking switches from ascending descending strength and as Andy said 38/99 should pop to the top, second to the iboost obviously.
