Hymermobil 534
Discussion in 'Motorhome Chat' started by Airforce1, Oct 22, 2010.
  1. Airforce1
    Airforce1 Read Only Funster
    Oct 22, 2010
    Hello all, I'm new to motorhoming having just bought a Hymermobil 534. It was imported from Germany so I'm having trouble working out how things work. Despite obtaining a copy of the Hymer manual, I can't work out how to use the leisure battery. The Battery 2 indicator is on zero despite charging it and there is no response from the interior lights, water pump or blow heater. The fuses all look fine and a couple of lights work when it's hooked up to the mains.
    I would be grateful for any guidance or help......
    Thanking you in advance.
  2. savantuk
    savantuk Read Only Funster
    Jul 3, 2009
    751
    31
    Cumbria, Lake district UK
    It could be that the lights that come on are 240V, and are not operated by the 12v system..
    It sounds as though the consumer unit is not switched on. There should be a master switch somewhere, either on the consumer or distribution unit. If it is switched off, the battery condition indicator will read zero, and none of the 12v components won't work, no matter what the condition of the fuses, or position of 12v switches.
    Sorry I can't be of more help.
  3. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,493
    Narrfoook
    Hi and welcome to the forum :Smile:
    Where abouts are you ? Perhaps someone close by could pop in and cast a beady eye for you :BigGrin:
  4. bigfoot
    bigfoot Funster
    Dec 23, 2007
    4,002
    5,165
    Wirral
    What year is your van? Mine was a 1992 and the battery master switch was on the passenger foot well below the fuse rack.. It was operated by a removable red key,maybe that is missing. The switch on mine was made by Hella.
  5. breeks
    breeks Read Only Funster
    Jun 15, 2010
    135
    24
    glasgow
    534
    if its not on footwell then above caravan door whare control panel is depends on which year your van is,
  6. Jim
    Jim Ringleader
    Jul 19, 2007
    26,101
    77,159
    Sutton on Sea
    Hi Airforce1, we have quite a few Hymer owners, so I am sure you will get sorted soon enough. Welcome to the Fun:thumb:
  7. staging lady
    staging lady
    Nov 12, 2007
    1,134
    55
    North Wales in the Hills
    Hi and welcome.:welcomefunster:
    Lucille
