Hymer 1998, B534 on Fiat 2.5td
Hi All,
I'm trying to resolve the problem of a very slow drain from the shower tray, hand basin, and kitchen sink.
When the waste tank dump handle/valve is open it drains perfectly. Venting issue??
This tank is insulated and located inside another tank/box with polystyrene/aeroboard insulation between the walls of the two tanks. The outer "tank" has a black plastic "inspection" cover on the bottom with, perhaps, 6 screws. This is directly under the dump valve mechanism, I think.
It also has a large circular screw cap in the middle., under the drain cap of the waste tank.
If anyone has removed a similar tank, would you recall seeing any vent pipe system at the top?
I'm now satisfied that the pipes and joints are ok (after much disassembly, cleaning and careful inspection), that the tank is empty and that clear waste pipe entry to the tank is entering a clear empty tank.
So, it looks like it needs a vent, or if has an existing vent, it needs to be unblocked.
If a vent ispresent, .... where. is it?
Any guidance before going at it (lying on the ground) would be greatly appreciated.
Joe
Hi All,
Joe
