Hymer S550 water heater
Discussion in 'The Beginner' started by Cathy&Tony, Jan 5, 2015.
  1. Cathy&Tony
    Cathy&Tony Funster
    Jan 5, 2015
    17
    4
    Les Cabanne
    We have had our first MH for two months now, we are up in the Pyrennes and the Hymer S550 is outside in the snow while we plan our first trip to somewhere warmer.
    A friend has said that the hot water tank should have a mechanism to auto empty when the temp gets close to zero. Does anyone know if the Hymer will do this or have we already made our first big mistake
    Tony
  2. Chipster
    Chipster Funster Life Member
    Oct 15, 2013
    424
    259
    East Midlands
    Is it a newish van with a Truma boiler? If so then yes it will. It's a black/blue valve on ours and dumps about 4 deg. To reset you have to push a button in and turn the top of the valve when the ambient isabove the tripping point. Not sure about Alde systems
    • Like it Like it x 1
  3. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    what age and model is the water heater some have it and some do not. If the hot water is permanently on then no need to dump. If there is heating in the van it is probably ok but if allowed to freeze it could be an expensive mistake.
  4. Cathy&Tony
    Cathy&Tony Funster
    Jan 5, 2015
    17
    4
    Les Cabanne
    Oh dear, the vehicle is 20 years old - but in excellent condition generally.
    but the heating is not currently on.
    to be honest I don't even know where the boiler is.
    There is a gas powered general heater in front of a cupboard and I would guess the boiler which is dual fuel is located somewhere behind the heater in the bottom of the cupboard
  5. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    i have a 1996 b 534 which if i remember rightly, is the same rear u lounge layout as yours but on a fiat instead of a merc chassis. the boiler on mine is located in the bottom of the wardrobe next to the bathroom. to access mine you lift up the bottom panel and you can then see the red temperature dump valve .if its in the down position then it has done its job and drained the boiler . hope this is of help garry
  6. Cathy&Tony
    Cathy&Tony Funster
    Jan 5, 2015
    17
    4
    Les Cabanne
    thanks Garry, I'll check tomorrow, Tony
  7. Cathy&Tony
    Cathy&Tony Funster
    Jan 5, 2015
    17
    4
    Les Cabanne
    OK, I've got to the boiler, stainless steel unit in a black plastic enclosure model Truma BN10
    Also found a B10 (not BN10) Australian manual, everything points to a relief valve somewhere but I can't locate it
    two reinforced water pipes lower one white upper one red
    the boiler is mounted about 10 cms above the vehicle floor probably to accommodate the position of the external flue/air inlet
    can't think the valve is under the boiler - resetting would be a major task.
    anyone any ideas
    thanks
  8. Carol
    Carol Funster Life Member
    Oct 2, 2007
    10,934
    15,882
    North Wales.
    image.jpg Don't know if this is of any help but this is a picture of the boiler in our year 2ooo Hymer. Truma Boiler, the photo shows a red button/valve this is what you need to reset if yours is the same.
  9. Cathy&Tony
    Cathy&Tony Funster
    Jan 5, 2015
    17
    4
    Les Cabanne
    nothing like a drain cock, button or valve near the boiler. Truma say the the frost protection dump valve is at the discretion of the installer and could be one of many types. I know where the drain down valve is for the whole water system and I wonder if my particular MH has no boiler frost protection and that when minus temps are due I have to drain down all the water. That might make my skiing trips a little difficult though.
    Any thoughts, musings or observations would be most welcome.
    Tony
  10. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    • Like it Like it x 2
  11. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    6,094
    9,942
    Lincs/Cambs border
    Cath & Tony,
    Have a look along the hot water pipe work from the boiler, looking for either a yellow toggle valve, a red toggle valve, or a round white nylon thumbscrew. Also, if you have more than one pipe exiting the underside of the outer floor, then that's a good indication that there is a separate drain valve somewhere close by, but inside.
    If in a ski resort, surely you would have your heating on 24/7, and therefore no need to drain down? Just a thought, ie, nice and cosy with instant hot water. ;)
    Good luck,
    Jock.
  12. Cathy&Tony
    Cathy&Tony Funster
    Jan 5, 2015
    17
    4
    Les Cabanne
    I have been under the vehicle and the boiler sits directly above the rear leaf-spring support frame and I can't see or feel any pipe outlet
    One pipe from the boiler does go directly through the floor and I am guessing that this is an expansion overflow pipe, however as the floor is double skinned it could come out anywhere.
    I am getting a manual from Hymer.
    A dealer has told me that these boilers only had the relief valve fitted post 1995 so I guess I don't have one. Retrofitting should be an option.
    Many thanks for everyone who chipped in with advice
    Much appreciated
    Tony
  13. B-well
    B-well Funster
    Apr 19, 2008
    1,191
    946
    Kent coast
    cathy&Tony My 1995 Hymer 534 had dump valve but kept opening as faulty, took this out, have been on Ski trips in van last 5 years and never had no probs -4 some nights and no electric hook up, however ensure the van is warm inside. Also depending on how high up you go some hardened ski funsters at VT will be able to adsvise better look at the ski forum for more info.
    Pipes from my boiler went into a plastic manifold with white plastic drain down screw valve, this is where my dump valve was located at base of wardrobe. As pointed out you may not have one.;)
  14. Cathy&Tony
    Cathy&Tony Funster
    Jan 5, 2015
    17
    4
    Les Cabanne
    Thanks for that, I'm so new here I didn't know there was a ski forum !!!
    Tony
  15. gibbon
    gibbon Read Only Funster
    Feb 25, 2013
    308
    326
    Shatterford
    In our old 1992 Hymer camp the dump valve was on the floor below the sink, it was either a blue or red toggle type.
    The boiler was in the bottom of the wardrobe.
  16. TheCaller
    TheCaller Funster
    Sep 23, 2013
    2,008
    2,361
    Lincs
    I suspect some posters may have missed part of the point of the question. Either that or I've misread it.
    Tony is not holidaying in the mountains in the M/H - he lives there in his house & the M/H is parked up outside. That's why it's not all warn & toasty inside the M/H 24/7.
  17. JockandRita
    Aug 2, 2007
    6,094
    9,942
    Lincs/Cambs border
    You might be right Simon, but then again, Cathy & Tony could have been at a ski resort at the time of posting. We wouldn't have known either way from the orginal post, ;) ....................but I know what you mean. :)
    Cheers for now,
    Jock.
