Xabia
I have a 2007 Hymer B544SL and the nearside running light bulb has failed.
As it is very difficult to access the rear of the bulb holder I thought I would be clever and just remove the bolts holding the unit in, withdraw it and replace the bulb. No chance, the large rectangular black box behind the main part of the headlight stops the whole thing from coming out.
So the other alternative is to remove the inner wheel arch and get to it that way but that seems a bit of a faff to do just to replace the bulb.
Has anyone else had the same problem and discovered an easy way to change the bulb?
Mike
Mike
